Old 03-27-2015, 10:29 AM   #37
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Higher octane doesn't give more power it just prevents detonation. Only mention this for people that are unaware. Kind of rare to have reasons for an NA build with stock compression to require an increase in octane rating.
Old 03-27-2015, 10:54 AM   #38
scod4025
Drives: 12 LE 5d HB 1nz-fe Automatic
Yes just getting myself use to price so when the S/C goes on wont have to alter budget
but I do notice a bit in my mpg maybe a .5 to it that's why I run it
scod4025 is offline   Reply With Quote
Old 04-07-2015, 12:49 PM   #39
scod4025
Ok so not much to report as my funding is low do to taxes but got board and remove the rear seat and spare tire/jack
Old 04-07-2015, 01:28 PM   #40
LTHatch
Drives: 2013 Yaris Hatchback L
Thank you for the correction my good sir fnkngrv, scod4025 how far are you going with the weight reduction? Any pictures of it gutted?
LTHatch is offline   Reply With Quote
Old 04-08-2015, 08:36 AM   #41
scod4025
I'm Planning on stripping it as far as I can but still owe a little on it so keeping what I do easily reversible for now, but also looking at doing a full custom interior that I can remove for when its play time (Basically a show car that I can race) and I will get some pictures of the striped back seat in a bit (have to wait till break)
Old 04-25-2015, 03:57 PM   #42
scod4025
Crank Pulley bought and installed!!!
and just a heads up the DIY for this seems to be gone but easy to figure out but really recommend an impact wrench with torque settings to do this install on a automatic fought it for like ten minutes then got the air hose out and solved the problem
Old 05-16-2015, 03:00 PM   #43
scod4025
Ok sorry haven't gotten the pics up for the gutting so here you go I'm also starting on panels as well as you can see
Old 05-16-2015, 04:50 PM   #44
LTHatch
That's awesome! Are you going to remove the seat brackets, seat belts as well? Any chance you can weigh the pieces you removed? I just want to verify my scale is right, rear seat delete with brackets and all seat belts, 60ish lbs off.
Old 05-17-2015, 12:05 PM   #45
scod4025
Hmm now I will have to weigh them as feels heavier then 60lbs.
Thinking about removal of belts but need to install seat once a month so if it is a pain to install them again probably wont but have gotten good at getting seat in and out so might be the same with practice,
on that note is there a torque requirement that anybody knows about for belt anchors or is it just till its tight
Old 05-17-2015, 01:46 PM   #46
LTHatch
Removal of the seat belt is easy, those steel seat brackets take longer to install then the seat belts. Until its tight works fine for me, i'm sure there's a torque spec for it maybe someone can post it if they know.
Old 05-29-2015, 12:36 PM   #47
scod4025
Ok so did one better got my car on a scale so with full tank car weight 2320
But with this scale rounds up to the next ten so if it was 2311 still would be 2320
it was 2490 with me in the car and I was upset as been aiming for 170 for weeks
will go back with some 1 lbs and will get right weight
Sent from my SM-G386T using Tapatalk
Old 07-06-2015, 04:13 PM   #48
scod4025
Ok so haven't posted in about a month so thought I would give a little up date
stripped more of the inside paneling out and did the door panels and removed the seatbelts and the brackets one thing that sucks though is that the speakers in the doors are pop riveted into place so didn't pull those out yet but here are some pictures
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 07-06-2015, 04:16 PM   #49
scod4025
Also got some eyelids and smoke tint for the brake lights
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 07-06-2015, 04:23 PM   #50
scod4025
But with all that said have a slight issue as when I removed the back door panels the rear windows stopped working so need to jump one of the wires in the plug to get them to work again and would like to know if anyone *cough* CTScott *cough* may know which ones I need to jump or have the diagram of the door panel if not will find it just take me a little bit with a meter. Here are pictures, if anyone needs more info let me know
[IMG][/IMG]
[IMG][/IMG]
Old 07-06-2015, 06:31 PM   #51
Red to yellow and green to black.
Old 07-06-2015, 06:33 PM   #52
scod4025
Thank you so much
Old 07-06-2015, 08:00 PM   #53
LTHatch
Very nice! You can still remove those steel seat brackets on the pillar(2 bolts) for a little more weight loss, also are you planning on removing the radio and all speakers(about 5lbs total) or just the rear speakers?
All that weight out the car feels so much better in 1-3rd gear, now maybe its time for a race battery on yours lol.
Old 07-08-2015, 09:05 AM   #54
scod4025
For right now going to just be pulling out the rear speakers rest will probably come out when I get done doing the fiberglass back deck as will have stereo in that, That is self contained so easy removal, and yes can remove the seat latches but I forgot about them and then was doing measuring and might use them as an anchor point for side panels in the back deck but will see as haven't got plan fully put together on how I want it to look
Blitz install has begun!! wildmongoose26 Forced Induction Forum 6 03-20-2013 09:41 PM
yaris mods have begun... matrixmanvvtl_i Cosmetic Modifications (Exterior/Interior) 12 10-01-2007 03:26 PM
