Old 04-16-2007, 12:54 AM   #1
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Found Something
Is this new or old?
I need Verification Please!
Now we come to the juicy bits. The 1.5 16 valve DOHC VVT-i 1NZ-FE engine has been turbocharged with light boost pressure as the compression ratio of the engine is still quite high for a turbo-ed engine at 10.5:1. Normal for a bolt-on setup. The ECU has been upgraded to detect boost and adjust air-fuel appropriately.
This results in 143 horsepower at 6400rpm and 196Nm of torque at 4400rpm. The gearbox is a 5-speed close ratio gearbox for maximum acceleration. This takes the car from 0-100km/h in 8.1 seconds. The car does the 400meter sprint at 15.9 seconds.
http://paultan.org/archives/2005/11/...ta-vios-turbo/
The link was found at the Bottom of this page!
http://en.wikipedia.org/wiki/Toyota_Vios
Thoughts?
Nutzoids is offline   Reply With Quote
Old 04-16-2007, 12:58 AM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
This is real old, Thomas has Video of a Turbo Vios from WAY back when
Old 04-16-2007, 03:21 AM   #3
yeah... standard TRD turbo kit for 1NZ-FE, which would cost a little upward of US$4000 if I were to get them to do it. 4K for just 50% horsepower extra's not exactly stellar
Old 04-16-2007, 07:00 AM   #4
kwiken
Drives: turbo vios 1NZ-FE
Originally Posted by Nutzoids View Post
Is this new or old?
Thoughts?
I posted that info to paultan.org in 2005 with photo's.
kwiken is offline   Reply With Quote
Old 04-16-2007, 09:41 AM   #5
Nutzoids
Nutzoids's Avatar
Well then I found it...
Thanks for doing all the work!
*Philosophy of life... Brought to you by... "Nutzoids"
Nutzoids... Where Punk rock is less about Image, and more about the Mind!
Old 04-16-2007, 10:01 AM   #6
Black Yaris
der Zeck
$4000 compared to... how much was a 2zz swap?
Old 04-16-2007, 01:15 PM   #7
2ZZ swap's a little pricier, around $5000. But you do get 190hp from an engine that is running in spec, as well as the close ratio 6-speed gearbox
Old 04-16-2007, 04:39 PM   #8
spkrman
Drives: 1
i'd love to see the 2zz swap over here.
Just Some Things I Found Nutzoids DIY / Maintenance / Service 4 04-03-2007 07:23 PM
Check what i found Kitt Cosmetic Modifications (Exterior/Interior) 5 02-23-2007 08:56 PM
Found Something... Please advise! Nutzoids Performance Modifications 19 01-15-2007 04:58 PM
some clips i found esquiva Photo-Video-Media Gallery 3 09-07-2006 01:27 PM
found out something cool... birdy General Yaris / Vitz Discussion 7 04-13-2006 02:05 PM
