Old 04-17-2015, 03:39 PM   #1
olls205
Drives: Yaris 2003
best wheel size for 2003 yaris??
ive been looking at getting 15x8, but been told 8J would stick out the wheel arch, i want a size that wont stick out but wont be too far in if that makes sense? thankss
olls205 is offline   Reply With Quote
Old 04-17-2015, 03:50 PM   #2
15x7 or 16x7 with an offset value in the neighbourhood of +40. Wrap them in 195 series rubber and you're good to go. Fronts will sit nice with that setup. Add 5 to 10mm spacers in the rear to push them out a bit more to line up with the front.
Old 04-17-2015, 07:08 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
15x6.5 with 195 55 its what im running and 42 offset ..perfect fit
Old 04-17-2015, 08:33 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
On a 2003, you would run 185/55R15 tires or 195/50R15.
185/55R15 is the stock size of the T-Sport.
Old 04-28-2015, 02:41 PM   #5
olls205
Drives: Yaris 2003
thanks everyone for the help. i have found a set of wheels i like the size is 15x7.5 ET10. im guessing ET10 is too low? heres the link... http://www.ebay.co.uk/itm/2713812752...%3AMEBIDX%3AIT
i think these would look pretty sick :)
Old 04-28-2015, 07:03 PM   #6
Yeah, ET10 on a 7.5 is asking for trouble.
Old 04-29-2015, 09:10 AM   #7
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I have 15x7 et35 with 195/50 tires. They will rub on hard compression. My old 16x7 et 42 with 205/40 tires fit perfectly with no rubbing at all.
Old 04-29-2015, 02:43 PM   #8
olls205
Drives: Yaris 2003
thanks alot, i will look for some with bigger offset, what is the minimum offset you would suggest? cheers
Old 04-29-2015, 03:09 PM   #9
Bluevitz-rs
Depends on how low you want to go.
Old 04-29-2015, 04:46 PM   #10
No offset number lower than 35, on a 7 inch rim with 195 tires.
Old 04-30-2015, 05:27 AM   #11
olls205
Drives: Yaris 2003
cheers weeyari, already got the 195 tyres just need the wheels now :)
Old 05-02-2015, 11:58 AM   #12
olls205
Drives: Yaris 2003
so if i was to lower my yaris by 40mm would the wheel size still ok? 15x7 ET40..
Old 05-02-2015, 01:12 PM   #13
Yeah, you would be good. Best to error on the side of caution. With ET40, you are leaving room to push wheels out a little further, with relatively little expense, using wheel spacers.
I once ran 16x7 with 195 rubber, ET42. Liked the way the front sat, but wanted to widen the track in the rear. Used 10mm spacers giving me an effective offset of 32. Liked the look, but did rub some in the rear when lowered 1.5 inches. Spacers are available in thicknesses ranging from 3mm to 15mm, with 5 and 10 being the most common.
I reiterate, you can always widen the track with a conservative offset. You cannot narrow the track with an aggressive offset wheel.
This is how mine looked with the described setup. The MK1 will be similar.
Old 05-02-2015, 03:42 PM   #14
Bluevitz-rs
You have to remember this is the 2003 chassis not the newer '06+. My et35 rub on the outside with a 25mm lowing on hard compression. So 40mm lowering would rub all the time at any more than a et40 offset.
Old 05-02-2015, 04:29 PM   #15
^ pretty much why we are trying to ensure he settles with nothing less than et40. He would be starting off safe, and if he so chooses to in the future, can widen out with spacers. We are making headway here, getting him off of the 7.5 et10 path he briefly entertained.
Good steering wheel lock for Yaris. edmscan General Yaris / Vitz Discussion 7 08-14-2012 09:33 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 12:03 PM
