#145 |
![]() ![]() ![]() ![]() Drives: 2011 Toyota Yaris Join Date: Feb 2013
102k here :) Purchased from my Uncle when it was all stock besides a mild drop from Tein S Tech springs at 80k miles. Here she is now! On Megan coils/Swift springs.
#146 |
![]() Drives: 07 yaris rs Join Date: Jun 2011
230,000 km = 143,000 miles.
no pictures of it, but its a 2007 bayou blue 5 door yaris rs. i put a tooter manifold and 1zz tb on it last year, konig heliums this spring and I'll be putting on some 09 rs bumpers because my front is cracked and the rear has a hole in it. nothing big to fix really, did front brakes, oil changes and filter changes and replaced tires a couple times. |
#147 |
![]() Drives: 2011 Blue Yaris 1.5 Join Date: May 2015
I am seeing the water pump being an issue for many. that is an easy fix :)
#148 |
![]() Drives: 2007 THREE DOOR 5 SPEED Join Date: Aug 2009
177,000 here. Still on original brake pads. Recently changed the manual tranny fluid to Redline. Soooo smooth. Replaced the serpentine belt and side window trim this morning. Best car I've ever had, and I've had a bunch. Bought it on a whim to pull behind our motorhome. The motorhome has been long gone but I will NEVER part with my egg.
#149 |
![]() ![]() Drives: 2009 Yaris 3dr Join Date: May 2009
My 09' HB has 108k and still getting 40+ MPG.
#150 | |
#151 | |
#152 | |
), and then donate it....in one fashion or another. If I ever come across the proverbial little old lady who has an '11 5-speed Meteorite Metallic or White 3-door with the split rear seat...who 'only drove it to church on Sunday' (so to speak)...and has decided to part with it, I'd probably buy it in a heartbeat.
#153 |
![]() Drives: 2008 Yaris Sedan Join Date: Oct 2012
149,000+ miles (240,000+ km) on an '08 manual that my 17 year old learned to drive standard on and still going strong.
#154 |
In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
now at 357000km about 222000 miles on the body and the second engine has 264520 km or 164365 miles due to hydro locking the first engine! Still running strong, this car has been through alot, and still getting over 600km/375 miles per tank. Replaced broken lowering spring, center exhaust and have to change the clutch.
#155 |
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
#156 | |
Yeah, plus savings over what? A reference point/comparison point present to figure savings/a break even point. When considering new cars in 2006, I compared the Yaris to the Prius. I figured the break even point was north of 300,000 miles on a Prius, and that assumed not having to replace the hybrid battery. |
#157 |
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
180xxx here, bought it with 5k on the clock in '09. Only things that have had to be replaced are the shifter cables, right rear wheel bearing, and the serpentine belt a few times (aside from the 2 accidents).
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
#158 |
![]() ![]() ![]() Drives: 2007 Toyota Yaris S Sedan Join Date: Jul 2007
Why did you replace the shifter cables?
Sent from my SAMSUNG-SM-N910A using Tapatalk
![]() http://www.youtube.com/watch?v=YnTlNLz9Iqc http://money.cnn.com/galleries/2010/...le_cars/5.html http://www.subcompactculture.com/200...-miles-on.html |
#159 | |
Currently, how high is 'the summit'...how many miles on your Yaris ? |
#160 |
Thank you! I currently have roughly a measly 543,000 miles on my Yaris. This may sound crazy to the average person out there, but I'm going to turbocharge it in the near future. My Valve Seals have now started to leak when I run thru the RPM's. So, I'm burning oil and have to top it up about every 1000 miles.
You never answered my question as to why you changed your shifter cables... Lol. I'm really interested to know why and if it fixed your problem. Bcuz currently I have a rattling noise from my linkage on my gearbox. But when I pull or push the shifter towards any gear while in neutral (which I'm basically put tension on the shifter cables by doing that), the noise goes away. So, I was thinking that maybe I should change out my cables too. Let me know what your issue was with your cables. Thanks! Sent from my SAMSUNG-SM-N910A using Tapatalk
#161 | |
. You are quite an inspiration, so members like to hear about your current odometer mileage (...and putting on many fewer miles than you used to doesn't change that curiosity) and what you are currently doing with your Yaris |
#162 | |
. Mind you this was the first year I had owned the car with roughly 30k on the odo. Not sure what was wrong, or what caused it, but they set me back $287.
| Mid-West Chapter Micro Image Car Club | lilredrocket | Southwest | 10 | 10-05-2009 01:06 PM |
| 30,000 mile service: Dealership or non-dealership? | EstherK | DIY / Maintenance / Service | 1 | 11-12-2008 12:40 PM |
| 11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) | Jerkratt | NY / NJ/ CT / PA | 14 | 10-26-2008 05:51 PM |
| Japanese Mix Club Los Invitamos!!! | TunTun_yariS[PR] | Caribbean | 0 | 12-12-2006 12:03 PM |
| Buddy Club Wheels | BulletProofAuto | Sponsors Classifieds Area | 8 | 10-19-2006 06:55 PM |
