Drives: Toyota Yaris model 2006 Join Date: Jun 2015
Replacing the luggage door lock (cylinder)
Hello
![]() I am a proud owner of a 2006 Toyota Yaris. I want to replace the luggage door lock. It is probably the cylinder that has rusted. I have tried to find a guide on the nett, but to no avail. Anybody here that have any experience? Sincerely A not so handyman |
Check out my DIY for replacing the lock with a scion IQ switch, as it shows how to remove the hatch plastic and how to get to the lock assembly: http://www.yarisworld.com/forums/showthread.php?t=39677
![]() ![]() ![]() Drives: 2007 Yaris 5 door RS Join Date: Nov 2014
Have you tried disassembling it? They corrode internally but 20 minutes with some coarse sandpaper and grease should bring it back to life. The corrosion causes the internal cylinder to get bigger. It then gets "stuck" inside the outer shell and the entire lock seizes (cannot turn it without bending your key, sometimes can't even push the button in at all).
Otherwise, you'll be looking at paying a locksmith to rekey the lock (or having another set of keys just for the hatch). |
| Clutch Master & Slave Cylinder | duendeverde | DIY / Maintenance / Service | 9 | 03-28-2016 05:31 PM |
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
| Canada Only - Maybe a $1000 enviro rebate on Yaris> | MDF | New YARIS Purchase Forum | 45 | 05-01-2007 08:17 PM |
