Old 06-11-2015, 08:34 PM   #19
Originally Posted by rider99 View Post
That I'm only getting 11.5 volts from alternater
Check the ALT-S fuse. If it is bad, the alternator will not turn on and you will just run off battery power.
Old 06-11-2015, 08:50 PM   #20
2009Toyotoad
Drives: 2009 Yaris 3dr
rider99 based on the electrical damage to the car. perhaps its not a bad idea that you get checked out too. You weren't grounded any more than the car was.
And while you may be feeling fine, your calcium and potassium are likely out of balance which could mean trouble in a few days.
2009Toyotoad is offline   Reply With Quote
Old 06-11-2015, 09:15 PM   #21
What??????
In a car is about the safest place you can be when lightening strikes. Lightening is only an issue for the human body if it finds its path to ground through you. I have been on many an airplane that has actually been struck directly by lightening.
Old 06-12-2015, 08:33 AM   #22
rider99
Drives: 2007 yaris sedan
Another thing I did not mention is the idle is higher than normal
rider99 is offline   Reply With Quote
Old 06-12-2015, 08:33 AM   #23
rider99
Alt fuse good
Old 06-12-2015, 07:39 PM   #24
Alt fuse good
ALT-S?
If so, you may be looking at a damaged voltage regulator within the alternator.
Old 06-13-2015, 10:56 AM   #25
rider99
Yes alt_s
Old 08-16-2015, 12:44 AM   #26
rider99
Just an update sent to dealer 3800 repair bill thank goodness for comprehensive and small deductibles
