![]() Drives: 2007 yaris 2014 rav4 Join Date: Sep 2014
steering wheel clunk
I can feel a clunk through the steering wheel as if the spiral cable is moving side to side inside the column. Is this normal? This happens when I move the steering wheel.
![]() ![]() Drives: '10 Fit Sport MT and 2012 Fit Join Date: Oct 2008
Doesn't sound normal.
The steering should be quiet. Clunk is hard to associate with a cable, rather with a steering rack or tie rod end issues. Have it checked as soon as you can. Steering is critical for safety. |
Can feel it is something in the column not the rack
![]() Drives: 2007 Yaris LB Base Join Date: Jun 2015
At least in the states, there is a recall out on the spiral cable. Could be that: http://repairpal.com/recall/14V168000
If you had the spiral cable replaced, it could have been done improperly. |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY - Converting a 2nd gen Yaris to the best part of a 3rd gen (Steering wheel audio) | CTScott | DIY / Maintenance / Service | 12 | 01-22-2022 03:09 AM |
| clunk in steering - steering shaft | tmontague | DIY / Maintenance / Service | 0 | 06-16-2015 09:07 AM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 10:16 AM |
