Old 08-11-2015, 10:18 PM   #19
KTS
KTS's Avatar
Drives: Vitz RS
Connect the rpm signal to the beige wire at the obd port. At idle (600rpm) the rpm switch display fluctuates between 1700-2600.
The rpm switch is most likely faulty. I contacted the supplier and awaiting a response. I will connect an autometer rpm activated module at 3000rpm and test hopefully tom.
KTS is offline   Reply With Quote
Old 08-12-2015, 06:47 PM   #20
KTS
KTS's Avatar
Drives: Vitz RS
Installed the autometer rpm activation module today and the system works flawlessly. The pressure switch activates the fuel controller as soon as boost is detected. No ping is heard. Afr on aem gauge reads 11's to low 12's in boost.
Old 08-12-2015, 06:59 PM   #21
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Awesome! Congrats on getting it sorted out.
Sent from my XT1031 using Tapatalk
Old 08-12-2015, 07:50 PM   #22
KTS
KTS's Avatar
Drives: Vitz RS
Would have liked for the activation point to be lower than 3000rpm. Jegs is replacing the non functioning unit. Once I get the replacement ill set the clutch activation to 2000-2500 rpm.
Old 08-25-2015, 07:52 PM   #23
KTS
KTS's Avatar
Drives: Vitz RS
With 92octane fuel, 1zz injectors and water meth spraying after the s/c I am still experiencing audible ping at partial throttle and wot even thou my aem afr gauge reads 10.5. My other performance mods are a fidanza flywheel and a k&n filter in the stock airbox.
Any suggestions? I am going to try some 95octane fuel but need to syphon out the 92 fuel tom.
Old 08-25-2015, 08:08 PM   #24
KTS
KTS's Avatar
Drives: Vitz RS
Forgot to mention I am using Denso double iridium tipped plugs with the gap closed in a bit heat range 20 (ngk 6). Was thinking to use heat range 7's. What you guys suggest?
Old 08-25-2015, 08:42 PM   #25
NGK BKR7EIX is recommended with the Blitz.
Old 08-25-2015, 09:06 PM   #26
KTS
KTS's Avatar
Drives: Vitz RS
Thanks CTScott I will pick up a set tom morning. The blitz S/C kit is exactly the little extra power this car needed. It would have been awesome if the yaris had this power from the factory.
Old 08-26-2015, 05:52 PM   #27
KTS
KTS's Avatar
Drives: Vitz RS
Installed a set of the ngk bkr7eix and I didn't hear any ping at all. Afr is 10.5 @ wot which mite be too rich??
Old 08-27-2015, 06:39 PM   #28
kou
Drives: 08 lb
10.5:1 afr too rich I'm running 15psi and 11.2-11.5 wot.
Old 08-27-2015, 11:00 PM   #29
KTS
KTS's Avatar
Drives: Vitz RS
Since you just confirmed that its too rich I have 3 options.
1. Install 1zz throttle body,
2. Reinstall 1nzfe injectors,
3. Use 100% water instead of 50/50 water/meth mixture.
What you guys think will be the best setup?
Old 09-06-2015, 05:45 PM   #30
KTS
KTS's Avatar
Drives: Vitz RS
Althou I am using ngk7 plugs and 255cc 1zz injectors along with an aem water meth injection kit I am still experiencing audible detonation.
Any suggestions or recommendations?
My only mod is a fidanza flywheel and using an autometer rpm switch to activate the supercharger at 3k rpm.
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 06:49 AM
Rebuilt Blitz Supercharger on Crashy CTScott Forced Induction Forum 12 04-13-2015 12:21 PM
For Sale: Blitz Supercharger Kit (and Gauges and AEM F/IC) CTScott Items for Sale by private party 16 08-27-2014 04:52 AM
Blitz Supercharger w/ fixed pulley and supporting modds blacksandiegovitz Items for Sale by private party 25 10-11-2011 01:45 AM
Blitz Supercharger and AEM Water Methanol Kit Morgan Items for Sale by private party 18 01-25-2010 11:54 PM
