Old 08-18-2015, 04:53 PM   #1
tmontague
tmontague's Avatar
wheel size with lowering springs
I've looked through the stickies but I cannot seem o find info regarding the following size and lowering springs.
I currently have MI lowering spring (-1.8" F&R)
I am going to be purchasing 15" diameter wheels by 7" wide and 38 offset. I plan on running my stock 15" tires on them as they still have a ton of life left. Once they wear out then I'll go with a similar sized tire but a bit wider.
I'm wondering will those rims fit my Yaris sedan with the MI lowering springs. I do want a closer look to the body but I don't need it so close that it's rubbing and causing issues.
Anyone on here have a similar set up or know if it will work? I measured and the offset should fit without a problem but I don't know how the wider rim will effect the fit
Old 08-18-2015, 05:17 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I can't see why you will have an issue. My AMR spring were similar with my wheels that were of the same specs. I have slight rubbing, but that is at a 205/55 tire. 195/60 even did perfectly fine for fitment.
Sent from my SCH-I545 using Tapatalk
Old 08-18-2015, 05:24 PM   #3
tmontague
tmontague's Avatar
thanks for the info
Old 08-18-2015, 05:32 PM   #4
fnkngrv
fnkngrv's Avatar
My rubbing by the way only happens on the front when I do a full turn lock from side to side.
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
TRD Lowering Springs. Alpha300 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 08-22-2011 11:36 PM
KSPORT GT vs. Tanabe DF210 Lowering Springs bad_bwoy007 General Yaris / Vitz Discussion 1 04-12-2011 01:01 PM
