Old 09-09-2015, 06:17 PM   #1
josephangel00
Drives: 2007 toyota yaris
Rear tail light problems....
My left tail light is currently out and not working.
I have checked the fuses and know its good, also the right side tail/brake lights are working and I know its only 1 fuse that power's both sides.
I have tried switching the light bulbs and that didn't work.
I have also tried swtiching out the the tail ends of that connected to the power and this also was not successful.
Any other things I could possibly try?
josephangel00 is offline   Reply With Quote
Old 09-09-2015, 08:49 PM   #2
Does just the tail not work, or do both the tail and brake not work?
If it is both, try jumping the white/black wire to a solid chassis ground and see if that makes it work again.
Old 09-12-2015, 06:40 PM   #3
josephangel00
they both won't work, call me an idiot here but how do i jumpstart a solid chassis ground? where on a yaris would i find this?
Old 09-12-2015, 07:38 PM   #4
My question was - On the not working side is both the tail light and brake light not working or is just the tail not working?
Old 09-12-2015, 08:35 PM   #5
josephangel00
They both are not working.
Old 09-12-2015, 09:37 PM   #6
Them both not working points to a ground issue, as that is the only thing common about them. By jumping it to a chassis ground I mean taking a piece of wire and making connection between the pin on the taillight connector and a chassis ground point (bare metal). Since the other side is working, you can also jump from the white/black wire one side to the other.
Changing the tail light vincentg DIY / Maintenance / Service 3 04-04-2012 08:07 PM
RS Tail Light Maybskee? xbr3akd0wnx Cosmetic Modifications (Exterior/Interior) 5 10-21-2010 03:26 AM
LED tail light question Julz Cosmetic Modifications (Exterior/Interior) 4 06-19-2009 09:25 AM
