Old 09-16-2015, 07:41 PM   #1
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
New engine MPG
So, I started to measure the MPG on my new car and the results were shocking: my 11 year Old manual Yaris had 25 MPG, the new one (automatic) 14 mpg. Both have the same 1.3 engine. I know manual transmissions lead to a lower MPG versus the automatic but not that much.
I've also heard that the car tends to consume more during break in period. Can somebody tell me if this is right?
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 09-16-2015, 08:04 PM   #2
Rigaud
Drives: 2009 Yaris
Opposite.....manual is better for MPG!!!
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 09-16-2015, 09:50 PM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Both of those numbers are way low. How are you measuring MPG? Something is wrong somewhere.
NYC-SE is online now   Reply With Quote
Old 09-16-2015, 10:46 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
City traffic only, AC on all the time. I'm not surprised by the numbers.
Sent from my A0001 using Tapatalk
Old 09-16-2015, 11:48 PM   #5
NYC-SE
NYC-SE's Avatar
14 MPG!!! I've driven trucks that did better than that. I drive in NYC traffic, with an auto transmission, the LOWEST tank I ever got on the Yaris was 28.8 MPG. Something is wrong with Kitt's calculations, either that or he parks the car with the engine running.
Old 09-17-2015, 08:28 AM   #6
Driving with shift lever in 3 and not D? It happens.
Old 09-17-2015, 09:12 AM   #7
nortonfb
Drives: 2007
What is the terrain like? Mountains? Uphill both ways?
I never had less than 30mpg driving 90 mph.
nortonfb is offline   Reply With Quote
Old 09-17-2015, 09:40 AM   #8
Kitt
Kitt's Avatar
I set the TRIP A odometer at 0 when I fill up, then I drive until the tank is almost empty, as much as I can drive. Then I divide the odometer millage between 11 gallons and that gives me the MPG right?
In other words, I can drive my '05 with a full tank for about 270.9 miles and the '15 gives me about 158 miles with a full tank. Both with ac on, same distance, i'll say moderate traffic at an average speed of 55mph and a regular terrain.
please let me know if I am doing the math wrong or something else. I'd really appreciate it
Old 09-17-2015, 09:43 AM   #9
Kitt
Kitt's Avatar
correct, sorry for that
Old 09-17-2015, 09:48 AM   #10
Kitt
Kitt's Avatar
not really sure what happens, I even put it on neutral whenever I'm on a stop light or not moving the car in traffic.
nope, I change it to 3 sometimes but i return it so it can shift to 4th
Old 09-17-2015, 01:47 PM   #11
IllusionX
Well, its kinda wrong. Because there is a little over a gallon in the tank when the light comes on.
I would calculate with reset trip, and drive until you fill up, and divide it with how much you filled until first click.
Old 09-17-2015, 01:58 PM   #12
Kitt
Kitt's Avatar
I'll check it that way to see if there is any difference and keep you guys posted. That would fix the low mpg values on both cars, however, the gap between both cars is still huge, regardless of the wrong initial values, keeping in mind that i am using the same method for both cars. the numbers should be close, if not the same. We are talking about 112 miles more.
I would also like to add that this is the first tank that I measure, so I have to keep tracking them to get an average.
Old 09-17-2015, 02:04 PM   #13
NYC-SE
NYC-SE's Avatar
What does the trip computer show for MPG?
Old 09-17-2015, 02:24 PM   #14
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
95% of my daily driving is "City Driving" (little/no severe 'traffic jam' type driving though), and my Average MPG Display indicates that I am averaging 38.x MPG. The amount of gas that I am purchasing weekly to fill back up validates those numbers.
Kalispel is offline   Reply With Quote
Old 09-17-2015, 03:50 PM   #15
Kitt
Kitt's Avatar
Mine does not come with a consumption display so I have to do it manually.
Old 09-17-2015, 05:31 PM   #16
NYC-SE
NYC-SE's Avatar
Hmmm. I thought all new cars had one. Anyway I just realized that Panama City is not Panama City Florida but Panama City Panama in your case which got me thinking. You guys are on the metric system, correct? Kilometers on the odometer and Liters on the pump right? I'm sure there must be some mistake in your calculations, most likely converting from KPL to MPG. When you fill up next time post your mileage as KPL.
BTW 1KPL=2.352MPG
Old 09-17-2015, 09:26 PM   #17
Kitt
Kitt's Avatar
We measure it as kilometers per gallon, so I do the conversion from km to miles and do the rest of the math as usual
Old 09-17-2015, 09:59 PM   #18
bgkz25
bgkz25's Avatar
Drives: 2006 Toyota Vitz 1.5Li
I thought the standard measurements are either mpg (miles per imperial gallon) or kpl (km per liter). I was wrong, it's different where you're at, metric and english.
Sent from my SM-N9005 using Tapatalk
bgkz25 is offline   Reply With Quote
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 03:47 PM
1ND-TV engine swap Daox Fuel Economy Forum 11 10-01-2015 03:49 PM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-13-2010 12:47 AM
195/60-15 Tires, premium and MPG Henry G. Fuel Economy Forum 24 09-10-2009 02:42 AM
