Old 09-18-2015, 11:22 PM   #1
AzianCuz
conundrum562
AzianCuz's Avatar
Drives: Toyota Yaris 2007 Type S
Send a message via AIM to AzianCuz
Question MICRO IMAGE - Light Weight Crank Pulley
So before I added the light weight crank pulley I was idling high like at 2000RPM+ now that I've installed the pulley it dropped it back down to normal.
As far as performance goes, it seems to lighten up the throttle. When I step on it lightly it speeds up normally but quicker, I have the S/C boost set on medium so it doesn't kick in until I step on it a little harder at around 4000rpm. The only thing is it doesn't seem to pull as hard as before when I had the old stock pulley...
I dunno anyone else notice any differences or better performance let me know?
BLITZ S/C|MICRO-IMAGE CRANK PULLEY|NST ALT;WATER PUMP PULLEY|BLITZ SUS SHORT RAM;HEADERS;AXLE-BACK EXHAUST|2.25 PIPING|1ZZ INJECTORS|OPTIMA YELLOW-TOP|GTSPEC FRONT STRUT;MID LOWER CHASSIS;4 PNT FRNT LOWER BRACE|WHITELINE REAR SWAY;BUSHINGS|TANABE FRNT SWAY|TRD LOWERING SPRINGS/SHOCKS|R1 CONCEPT DRILLED & SLOTTED ROTORS|EBC GREEN PADS|THROTTLE SPACER|XTREME PERFORMANCE CHIP MOD
AzianCuz is offline   Reply With Quote
Old 09-19-2015, 10:10 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It's not an under drive pulley is it? That would lower the rotational speed of the supercharger.
Old 09-19-2015, 12:30 PM   #3
MI didn't commission an under drive pulley.
Old 09-19-2015, 12:50 PM   #4
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I'm surprised a lightweight pulley can lower your iddle speed. I've never heared of that before.
You're right, the car it should accelerate the same way as a before, only it'll reach that high RPM quicker. That's the main performance benefit.
Which gear/rev range does it not pull as hard? Does it pull less? Keep in mind, this type of pulley will not create HP.
Old 09-19-2015, 02:22 PM   #5
AzianCuz
conundrum562
AzianCuz's Avatar
It's a crank pulley, Let me test it out some more and see what happens, it could be all in my mind... Also I have an automatic not stick, so that might be part of it too, but for sure my idle did drop to normal from this.
Micro Image JDM replica tails installed.. Kiteless Cosmetic Modifications (Exterior/Interior) 26 08-02-2014 01:49 PM
NST Lite Crank Pulley camelll Items for Sale by private party 5 03-15-2011 08:57 AM
6lb 6oz ultra light weight battery heavystarch Performance Modifications 28 11-19-2008 06:02 PM
NEW GROUP BUY: Yaris NST Crank Pulley (NonStopTuning) NonStopTuning NonStopTuning 224 05-17-2007 07:40 AM
unorthodox or Perrin Light Pulley abdiel hiram Performance Modifications 2 02-27-2007 04:45 PM
