Old 10-14-2015, 01:35 PM   #1
Silverkarn
Drives: 2008 Toyota Yaris 2D
Are there alternative jack stand spots? (08 Yaris)
2008 Yaris hatchback
I know where the jack points are in front and back for the floor jack, but i was wondering if there is anywhere else i can safely put jack stands without damaging anything besides the pinch welds behind the front tires and in front of the back tires.
All i have for jack stands are ones that have a VERY slightly curved bar at the top, I tried hockey pucks with a groove cut into them under the pinch welds, but the hockey puck started tilting off the stand as i slowly lowered the car down.
Silverkarn is offline   Reply With Quote
Old 10-24-2015, 10:55 PM   #2
billfires
Drives: 2010 3dr LB
When jacking my Yaris I use a 2"x8" board that allows me to lift the whole side at once. I would think you could do something similar when using jack stands. Bill C
billfires is offline   Reply With Quote
Old 10-25-2015, 10:10 AM   #3
ex-x-fire
I like to lift on the boxed section of the floor pan, sometimes called a subframe. This tread has some pictures for lifting the entire front or rear.
http://www.yarisworld.com/forums/showthread.php?t=9823
Old 11-10-2015, 12:26 AM   #4
SirDigby
Drives: 2007 yaris 3 door
yes that is good places. also you can jack on the subframe/body bolts, and the center uni-body rail/frame. if you look underneath you can see some rubber body plugs where the vehicle was mounted on the assembly like, this is also a support area.
Old 11-10-2015, 06:33 AM   #5
tmontague
tmontague's Avatar
I finally got around to modifying modifying hockey push with an angle grinder. I'm lowered so I cannot aces the front lift point.
I usually jack my car up about twice a month so the pinch welds are not adequate for that.
I now lift at the pinch welds using a puck and then place my jack stands under my control arms for the front (, close to the subframe , possible). For the rear I place the axle on jack stands this way there is no weight on the pinch welds.
Worked well this past weekend with no issues.
How are you guys jacking up your Yaris? touroxin DIY / Maintenance / Service 65 02-01-2015 04:42 PM
What is it about the Yaris Ranger SVO General Yaris / Vitz Discussion 18 01-06-2015 09:45 PM
WTB: 2006-2008 Yaris Stereo Wiring Harnesses, AUX Jack zerosktz Willing to Buy by private party 4 02-19-2011 02:41 PM
