Old 09-25-2015, 11:46 AM   #73
Originally Posted by metalshark View Post
Hi Scott. I installed the Rostra cruise on my 2008 Yaris. I have a 2012 automatic Yaris now. I have a stalk for it. Has anyone done a 2012 yet.
Yes. Same OEM stalk is used for 2012 as for 2008. Other than the different release of the airbag, there is no difference for 2012 from 09-11. I have the parts required if you are interested.
Old 10-29-2015, 11:19 PM   #74
thomascuba
Drives: Wife's Red Yaris 2007 AT 5D
Dear CTScott;
I would like to install the CC on my wife's 2007 Yaris Base A/T (Hatchback).
Do you still have OEM parts available?
What parts do I need and how much will it cost me? I will prefer not to drill holes on the wheel cover.
Thanks!
thomascuba is offline   Reply With Quote
Old 10-30-2015, 06:31 AM   #75
Originally Posted by thomascuba View Post
Dear CTScott;
Thanks!
Yes. PM sent.
Old 11-11-2015, 09:02 PM   #76
thomascuba
Wiring Missing
Dear CTScott;
I have sent you a PM. I will go ahead and install the CC. But I need to purchase some wires from you.
Thanks Thomascuba.
Old 11-11-2015, 09:16 PM   #77
thomascuba
Missing Wires and Pictures of the Stalk I Got from Friend
Hi CTScott;
Here are the pictures of the Stalk I got.
Thanks, Thomascuba
Old 11-14-2015, 03:33 PM   #78
soldout
soldout's Avatar
Drives: 2010 Blazing Blue 3 Door LB
The cruise control light comes on my dash but I cant get it to activate. 2010 LB 5spd MT power package so I alreadt had the clutch switch wiring.
15' - Crosstrek Hybrid ~ Plasma
10' - Yaris 3 Dr LB ~ The Boom Box
06' - RSX Type S ~ H.S. Dream Car
95' - Delsol VTEC ~ The Racecar
12' - Burgman 400 ~ Garage Queen
09' - Agility 125 ~ 80mpg Daily Rider
09' - Metropolitan ~ Weee
14' - Ecosmart Metro ~ Razor
soldout is offline   Reply With Quote
Old 11-14-2015, 10:59 PM   #79
Did you actually install the clutch switch and is it properly adjusted, where it is fully pressed when the clutch pedal is not touched?
Old 11-15-2015, 09:03 AM   #80
soldout
soldout's Avatar
Yes, the switch wiring was taped up under the dash right above where the switch mounts. Im going to try and re adjust the switch but Im pretty sure the button is fully depressed when my foot is not on the clutch.
Old 11-15-2015, 10:49 AM   #81
I don't recall having sold you the kit, so you may want to check to make sure that the clutch switch is correct (there are two types that operate in the opposite way of each other).
Old 11-15-2015, 11:57 AM   #82
soldout
soldout's Avatar
Silly me, the first time I went to test I forgot to plug in 1 cable for the steering wheel sensor so my traction light was on, doubt CC will activate under those conditions. 2nd time I went out I plugged it in but just went around my neighborhood and wasnt going fast enough. Im my Yaris I think I have to be traveling at least 30mph to activate CC. Thanks for your help Scott.
Old 11-17-2015, 01:24 PM   #83
Eduardo_mty
To install Cruise control on 2016 yaris sedan automatic transmission, i only need
846330821 Cruise control stalk
84633-02020 Cruise control wire
90080-15079 screws
Eduardo_mty is offline   Reply With Quote
Old 11-17-2015, 07:37 PM   #84
90080-15079 screws
Correct
Old 11-18-2015, 11:31 AM   #85
Eduardo_mty
Thank you
Old 11-24-2015, 02:30 AM   #86
Tweete
Drives: Manual YRX 2009
Sorry if this has already been posted about but I seem to be reading a lot of conflicting information.
Can anyone help me?
I Live in Australia (right hand drive) and currently own a 2009 YRX Manual Hatch.
It has steering wheel audio controls.
would anyone please be able to tell me what my options are for cruise control?
Im a 25yr old female not so down with messing with electronic components however i want to look at my options before paying a bomb for someone to install an aftermarket kit for me.
Thanks in advance!
Tweete is offline   Reply With Quote
Old 02-06-2016, 06:41 PM   #87
adubtawa
Drives: 2008 Toyota Yaris 4DR
So the Toyota Yaris 2008 does not have the indicator on the instrument cluster for the engagement of Cruise Control? Is there any way to add this/upgrade the instrument cluster?
adubtawa is offline   Reply With Quote
Old 02-07-2016, 12:02 AM   #88
Only via my indicator module for 06-08 Yaris.
Old 02-07-2016, 10:37 AM   #89
adubtawa
What about if you change the instrument panel to an 09?
Old 02-07-2016, 10:41 AM   #90
No. The ECM for the 06-08 does not support the CAN message to the cluster to turn it on.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 01:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
