#37 | |
The stock engine should be well able to handle that mild power, and if not, well just more time spent for me to learn how to rebuild an engine. I'm planning on having my Yaris for another decade at least so it gives me a DD when my hobby car is on a lift ;)
#38 | |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
#39 |
Ya they're not a Toyota that's for sure. I've been following a lot of the Subie forums for the past half year and most of the issues seemed to stem from heavily moded wrx's. The head gasket can happen even to the stock one's but as for the oil delivery issues it seems to happens when pushed passed red line for prolonged periods of time with added boost.
The only other option would be to spend a lot more money on a '14 model with a new 2.0 engine that is still too new to determine durability. My budget may only allow for an '11 or '12 and then just pull the engine and work on it as needed. The way I see it is a headgasket job is cheap if you don't mind putting putting time in. And since i'll have my dependable Yaris to drive while the WRX is out of commision, it sort of a win win. It's still a couple years away for me so a lot of time to learn/read more and see how the prices fair down the road.
#40 |
2ZR swap. DO IT! Ask how!
From my conversations with RagnaCat (PR, 2ZR swap) about gearboxes, the drive shafts are different on the transmission side. I've got a few different stock differentials (minus ring gears) in my parts bins, and I know how to rebuild a C5x gearbox, so this wouldn't be an issue for me. If you want it to be plug and play, you really need an xD MT as a donor. As far as I can tell, the bell housings are compatible, assuming that the starters are in the same spot.
#41 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
From all of the images I looked through on the internet, and remembering the starter positions during the swap. I'd say the starters are in the same position. AGAIN, this is why Im getting another 2zr to test fit with my spare yaris trans and flyweel/clutch.
#42 |
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
I was checking on act, spec and fidanza websites. From act I see that the 2zr and 1nz user the same pressure plate and clutch disc however the flywheel part numbers on spec website differ for the two; 1nz=st51a while 2zr=st16a. Therefore if the 1nz gearbox/tranny built to the 2zr all u may need is the 2zr flywheel for the drivetrain
#43 |
Data doesn't lie
I saw this too, this is why all I need to do is try bolting the 2zr and C5 together and then we have the answer !
#44 |
I can't wait for the answer. Tomorrow I am going to look for a 2zr locally.
#45 |
Data doesn't lie
I just heard there is someone making long-tube headers for the 2zr? Someone in Az?
#46 |
![]() ![]() ![]() Drives: 2013 Yaris Hatchback L Join Date: May 2013
http://www.fastscions.com/rpm-long-t...2008-2012.aspx Is this what you're looking for?
#47 | |
http://s1081.photobucket.com/user/RP...?sort=3&page=1 http://www.rpmheaders.com/index.html
#48 |
Data doesn't lie
Thanks guys!
#49 |
Oh man, I haven't visited YW in a while. Glad you finally posted this up. I remember talking to you about this and how there needs to be a new thread on this because RagnaCat had a huge build thread on MicroImage forum that is not lost in the ether.
One day this will happen to my yaris. Would be a 2zr supercharged to compete in the SMF class.... Would definently turn some heads
#50 |
Data doesn't lie
I am moving next month, and once Im settled I will be researching an Xd to buy. I will then begin the swap process on my own car with lots of pictures for a proper diy.....I will be joining the SMF class also, but going the n/a route
#51 |
I am having issues trying to find a Xd that is less than $5k.. I want to do this same swap but would prefer a donor rather than buying piece by piece. Seems like nobody totals out their Xd around here
#52 |
Data doesn't lie
Ive seen several here in California but they are owned by auctions....around $3000 for a totaled xd.....Id rather buy a used xd, swap what I need to the yaris, then slowly rebuild the xd and sell it.
#53 |
Wouldn't a 2zrfe corolla swap also work? Maybe the mounts and exhaust is different from the XD but it would a lot easier to find donors.
#54 |
Data doesn't lie
Yes a corolla donor would work for the engine and ecm, if you want to go that route
| Toyota Hybrid R Shows Its Yaris Roots | MadMax | General Yaris / Vitz Discussion | 0 | 10-10-2013 07:14 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 03:32 PM |
