Old 12-13-2015, 09:20 PM   #109
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yeah, that was actually the engine backfiring. With how much has changed the cold and hot tunes need to be adjusted a fair amount. We also need to figure out the fuel issue.
Sent from my XT1575 using Tapatalk
Old 12-14-2015, 09:44 AM   #110
Focus_Sh1ft
Focus_Sh1ft's Avatar
Sounds amazing!
BTW, what tails are those, altezza?
Old 12-14-2015, 10:25 AM   #111
fnkngrv
fnkngrv's Avatar
The tails are spyders. Mine are the smoke version. Not sure if carid still carries the smoke, but here is the link to the standard ones:
http://www.carid.com/2007-toyota-yar...ts-439658.html
Old 12-20-2015, 04:46 PM   #112
fnkngrv
fnkngrv's Avatar
As previously stated the hydrodipped CF valve cover was damaged due to rubbing issues so I decided to have the cover PC'ed to match the new IC piping. Also upgraded the valve cover bolts to an ARP set which looks much better and will stand up to conditions for a long time to come. Unless mistaken I am now 100% completed under the hood.
Old 12-20-2015, 09:56 PM   #113
LTHatch
Drives: 2013 Yaris Hatchback L
That color is beautiful and almost distracting enough to hide that big snail attached to your Yaris lol
LTHatch is offline   Reply With Quote
Old 12-22-2015, 11:28 PM   #114
fnkngrv
fnkngrv's Avatar
Yeah I really love the purple for sure. We installed a shorty bullet stainless racing muffler yesterday. Really lowered the tone of the exhaust to a nicer less ricey note however didn't do much for reducing the db. I am thinking the only way to tame that is with another chambered muffler, but don't want to reduce performance.
Old 12-26-2015, 03:20 PM   #115
fnkngrv
fnkngrv's Avatar
Brought her home from the shop today and she is definitely running super rich. All that extra air makes a big difference. Working right now to figure out the schedule to take the car down to the Dyno and hoping to do it within the next 30 days. Can't really come to soon.
Old 12-26-2015, 08:15 PM   #116
LTHatch
That's great news, one last step in the way for you to set new land speed records. Should we start guessing how much she'll put down?
Old 12-26-2015, 08:25 PM   #117
fnkngrv
fnkngrv's Avatar
If you would like you can. I had hopes for certain numbers last year however learned to not count chickens before they are hatched. We are fighting with over boost situations right now and still the fuel pressure gauge not watching to cooperate. These will need to be resolved first. I have a 12psi spring in the wastegate so by what AEM says their boost controller does the max boost should not go over 24psi. The big problem is that my current boost gauge only goes to 20psi so I will need to invest in a new one.
Old 12-26-2015, 08:29 PM   #118
LTHatch
Over boost? Do you know what's causing that on your setup?
Old 12-26-2015, 08:33 PM   #119
fnkngrv
fnkngrv's Avatar
We aren't sure just yet. I had been set at 15 across the entire rpm range previously, but we have buried the needle at 20 the few times we have tested wot. It isn't over boosting per the controller ability AFAIK by the data logger, but still needs to be figured out since the fuel quality here isn't good enough to be hitting 20+ for me and feel comfortable.
Old 12-26-2015, 08:42 PM   #120
LTHatch
Ah ok, so i assume there is no E85 locally where you live or you want to stay with 91/93? So a 5 psi overboost and she held together? That is a dang good tune.
Old 12-26-2015, 09:19 PM   #121
fnkngrv
fnkngrv's Avatar
No e85 for at least 400 miles. Plan is street tune with 91 while still in Maine, then 93/95 in TX. Race tune will be with c12. My fuel pump isn't the model for use with e85, but everything else will support it.
Old 12-26-2015, 09:34 PM   #122
LTHatch
Sounds like a good plan, congrats on moving to a state with far friendlier car atmosphere. Curious how much the higher temperatures in Texas will affect your land speed runs.
Old 12-26-2015, 10:11 PM   #123
fnkngrv
fnkngrv's Avatar
All goes well I will be able to tell you in October. Plans are to race in the Texas Mile at the least and possibly the Arkansas Mile as well.
Old 12-27-2015, 02:36 AM   #124
Chief Quimby
Drives: Yaris Tsport
What compression ratio do you have.
I ran 33,5 psi on pumpgas oktan 93.
Is the overboosting in 4-5 gear, mabey wg is to small.
Do you have boostcreep in lower gears ?
Chief Quimby is offline   Reply With Quote
Old 12-27-2015, 05:37 PM   #125
fnkngrv
fnkngrv's Avatar
CP 9:1 pistons. We will figure out the boost issues once we get down to the Dyno. What were you running 33psi of boost on?
Old 12-28-2015, 09:48 AM   #126
Chief Quimby
Well, 33psi is maney abit to much at 9-1 :-)
Ran it on my starlet 5e engine, but the compression was low around 8-1
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
