Old 12-28-2015, 09:23 PM   #37
SirDigby
Drives: 2007 yaris 3 door
another thing to keep in mind is there is this stupid carbon filter on the top half of the airbox cover. it is plastic riveted in. if you remove this extra filter it's good for a few more CFM....if you plan to keep your stock box
Old 01-02-2016, 07:20 PM   #38
texascolt45
Drives: 2015 yaris
I have one of those drop in k&n's.hasnt helped the mileage or power 1 bit.going on 8000 miles.
texascolt45 is offline   Reply With Quote
Old 01-04-2016, 12:17 PM   #39
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
For what it's worth, I took the K&N drop-in out after first reading about MAF gunk up in this thread. After reading a bit more and learning it comes down to the amount of oil on it after cleaning, I put it back in. Noticed a smoother idle. Can't speak for power and MPG seems the same, but definitely noticed a smoother idle.
Old 01-16-2016, 12:40 AM   #40
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
K&N does not help much..i feel like it just saves money by washong, drying and putting them back on..
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 12:03 PM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
