#181 |
![]() Drives: Toyota Yaris 2014 Join Date: Jul 2015
Brown - 0
Grey (right of brown) - 5 - 5,5 |
#182 |
Interesting. I have not had the opportunity to measure the voltage on the CCS wire of a third generation Yaris, so the 5V, rather than 12V might be OK.
Try jumping the brown to the grey with the Ignition ON, but engine off (you can use a bent paper clip or small piece of wire). If you touch those two terminal together briefly you should be able to toggle the cruise control symbol on and off on the cluster, if it works.
#183 |
As far as I am aware, the 1.0L does not have the ECM programming for cruise control.
#184 |
No. You would need an aftermarket cruise control system, which can be quite costly.
#185 |
![]() ![]() Drives: 2015 yaris Join Date: Aug 2015
anyone try this on a 2015 1.5 liter L model with an auto trans?i'm curious to know if it will activate the cruise.
#186 | |
Yes. I have sold quite a few kits to people with 2015s.
#187 |
![]() Drives: 2013 Yaris 4d Join Date: Jul 2015
ECM pinouts question
Hi-
I have a 2013 Yaris which has a no start will crank problem. My ECM connector configuration and pinouts are different from those on the TIS documentation. Is there some way I can get valid connector drawings and signal lists? My ECM is a 89661-52R40. thanks |
#188 | |
Please post a separate thread instead of hijacking an unrelated one.
#189 |
Drives: '15 fire red yaris 1,33 vvt t2 Join Date: Dec 2015
Hi
which Toyota part number cc stalk do you yaris sorcerers recommend for my 2015 yaris 1,33 vv-t ? thumbs up from denmark wow first post
#190 |
![]() Drives: yaris diesel 2012 Join Date: Jan 2016
sorry for my poor english.first time in forum.In my Toyota Yaris D4D 2012/07 model STYLE TYPE- NLP130L-CHFSXW, everything is in place,and the clutch switch s in place in the pin 1-2 ihave 5 volts in grey wire and 0 in brown i have put a used oem cc switch and did not work!!i have read that european yaris not support cruise control.is it definately???any solution???thanks any way!!!!!
#191 | |
![]() ![]() Drives: Yaris 2014, Y. HSD 2013 Join Date: Feb 2013
ECM is a metal box located under the hood in difficult access behind secondary fuse box in right passager side. |
#192 |
ok i will search for pin 40 and if is not pluged anything what shall i plug on it???and second
can i reprogramm my ecm (not me offcourse)or something is missing from ecm? |
#193 |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
Big thanks to CTSCOTT for letting us know this was possible. I have just fitted cruise control to my 2012 Austrailan 1.3L yaris. I only bought the Yaris recently as a second car, and was nearly put off the purchasr because of the lack of cruise control. I found a switch on eBay for AU$17 delivered for whatwas a $650 option in 2012.
For the 2012 model with steering wheel audio controls you don't need to disconnect the battery or airbag, but it's a good idea to remove the horn fuse from the fuse box next to the battery when you go to push the central airbag and horn button back on to the wheel. If you don't the horn will sound when you push the airbag unit back on to the montings.
#194 |
![]() Drives: MY63 Toyota Yaris 1.33SRManual Join Date: Oct 2013
OK I finally done mine! I am from the UK, I ordered the cover part from toyota (part# 45186-0d030-C0 (C0 = black) and cost me £5.60 inc VAT.
I ordered a non OEM stalk off ebay for cheap but hopefully will last and looks/works/feels OEM. So disconnected the battery, removed airbag, put it all in, put all back together.. DONE! How long did it take... 10min? 15min? 20min? 30min?... nope! 1 whole hour!!!!! thats start to finish. 45min of that was battling the airbag clips! My car is a 2013 (MY63) Yaris SR 1.33 Manual 5door. It already had the secondary clutch switch etc so literally was plug and play. When connected battery, only thing that rest was the clock, the touch&go even resumed my song so dont worry about having to set everything again, just the clock! The first clip of the airbag was easy, small screw driver and push and it pops out. The other two... well lets just say I couldnt pull the clips down, they are tougher than I thought! How I got it out eventually was by pushing down in the plastic clips of the airbag which some how released both but this is easier said then done! I was violent so dont be scared, nothing will break as long as you know what you're jabbing. To help me get more access I also removed the steering wheel buttons trim by un doing two screws (1 is oposite the other and are obvious). It wouldnt come off as the airbag was still clipped in but I could pull it off enough to get more access. Thats my tip! |
#195 |
![]() Drives: 2014 Yaris lb 1.33L Join Date: Apr 2011
Hello
I have a yaris European model, engine 1nr-fe. CTScott, do u still have the kit for cruise control? Thx |
#196 |
Drives: Yaris Join Date: Mar 2016
Control buttons on the steering wheel.
Hello everyone.
I have a Toyota Yaris 2015, 5 door, the European version, with control buttons on the steering wheel. Does anyone know for what are the wires in the connector (D103 black) pin 10 - red ? pin 11 - pink ? pin 12 - blue ? I suspect that these pins are of a radio control. Can somebody confirm this? roninn Last edited by -roninn; 03-10-2016 at 03:20 AM. |
#197 |
![]() Drives: yaris 2016 Join Date: Apr 2016
hello.i have a 2016 1.33-VVTi Active 1NR-FE automatic eur model right hand drive.does anyone know if i only need the stalk?
#198 |
Correct - You just need the stalk and the replacement steering wheel side trim piece.
| Tags |
| cruise control. 2012 |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
