Old 01-15-2016, 09:04 PM   #1
Snowball2009
Drives: 2009 yaris hatchback manual
wiper upgrades
Wiper upgrades, wondering which part to use:
Wiper switch 8465252110 ? Or 8465212A20 ? What's the difference between these two? Currently have basic front and rear wiper function, you know 1-3 front w/mist, 1 rear w/mist. The goal is just to add a time delay function to front wiper and leave rear as is.
Snowball2009 is offline   Reply With Quote
Old 01-16-2016, 01:39 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
http://www.yarisworld.com/forums/showthread.php?t=15512
Old 01-16-2016, 06:26 PM   #3
Snowball2009
wiper
Thanks, for install info. This Will be helpful. Mostly though, I'm confused about which OEM time delay wiper part I want to get. The part in the link ( 8465252110 ) looks to be meant for a rear wiper with 2 rear settings, one of which will not totally work without additional rear wiring for the rear wiper with this install. I'm wondering if anyone knows if ( 8465212A20 )might also work, and if maybe it's more what I need. Which is a switch that has intermittent/mist time delay up front and just 1 setting with mist in the rear. The description for the 12A20 part number is confusing to me and I'm not really sure what functions it actually has. Think what I need is a part description de-coder.
Old 01-28-2016, 04:41 PM   #4
xdarkxfirex
Drives: 2015 yaris le
I didnt bother with the OEM. When I bought it, someone had put the cheaper standard metal wiper blades.I replaced then last spring when they were streaking. I bought cheap hybrids, and they broke during a snow storm last month :(
I ended up buying michelin all season hybrid wiper blades from a local auto parts store for $9 in canada. No regrets so far, seems like a good value
xdarkxfirex is offline   Reply With Quote
Old 01-29-2016, 10:48 PM   #5
Meeksworth
Drives: '13 Yaris LE
wiper upgrades
I've upgraded the wipers on every car I've ever owned, even the beaters.
Personally I'm a big believer in RainX and I love my RainX latitude wiper on the front. I upgraded the rear wiper to a 16" from the stock 12". The 16" fits perfectly. I suspect the 12" which is the shortest one available was only installed stock due to costs.
The stick upgrade is nothing without good wipers!
Meeksworth is offline   Reply With Quote
Old 01-30-2016, 09:59 AM   #6
marspike
marspike's Avatar
Drives: Yaris 2014, Y. HSD 2013
Great to known this trick!!!
marspike is offline   Reply With Quote
Old 01-30-2016, 03:08 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
I looked closely at my rear wiper. Because of the design of the OEM blade, I can't install a longer refill. So, I guess you replaced the blade. Which blade did you find that fits the arm?
Old 01-30-2016, 03:11 PM   #8
Meeksworth
wiper upgrades
You're correct, I didn't think about the refil because one replaces the whole blade on Rain X wipers. They don't make refills and their wipers are all one piece.
When you go shopping for blades you'll notice some that have a length followed by a letter. Those are for the rear. You need to get one that has the correct letter and just get a longer length. I think it's R that you need but check the guide before you buy it. I bought a rain x one because that's my preferred brand but any one with the correct connector type will work. For the record I bought one that I had to return because I didn't pay attention to the additional letter next to the length of the blade so be sure it has that.
Old 01-30-2016, 03:31 PM   #9
kimona
kimona's Avatar
Okay. Thanks a bunch. I'll check out the Rain X blades. I didn't realize aftermarket blades were designed to fit unique OEM rear blade wiper arms.
Old 05-26-2016, 11:10 PM   #10
Racecartimmy85
Drives: 2009 Yaris 5 door
A little late to the game but I just bought a 09, and noticed the front wipers are both a little short. The leave a rather large unwiped triangle area on the passenger side and a good size area in the upper driver's side corner. Has anyone put larger wipers on either front blades?
Racecartimmy85 is offline   Reply With Quote
Old 05-27-2016, 11:45 PM   #11
Tapokata
Drives: 2009 Yaris
It's the driver side that is too short on my 09 LB. The size guides at the store will tell you to replace with a 26" blade. Use a 27" instead. It will fit, and the annoying Bermuda Triangle vanishes.
Tapokata is offline   Reply With Quote
Rear Wiper Intermittent Delay Timer Mod toy_toronto DIY / Maintenance / Service 36 07-08-2016 08:04 AM
Rear wiper motor gone alex22808 DIY / Maintenance / Service 1 11-05-2014 11:27 AM
Rear Wiper "Coverage" Problem Solved Onwrdigo Third Gen Yaris General Discussion 5 06-20-2013 06:48 PM
Wiper blades .... Lafiro General Yaris / Vitz Discussion 81 02-02-2012 06:54 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
