Old 03-16-2016, 01:10 AM   #1
YodaBird
Drives: Gray
Replace control box in Yaris Model ?
Hi, did anyone get a letter in the mail for 2012-2013, Avalon, Prius & Yaris models to replace a control box under the passenger seat for a limited time for Free ?
YodaBird is offline   Reply With Quote
Old 03-17-2016, 07:04 PM   #2
YodaBird
Drives: Gray
No one received this letter ?
Old 03-17-2016, 07:45 PM   #3
LTHatch
Drives: 2013 Yaris Hatchback L
I have not received any letter of that nature, if it's free why not. Thank you for the heads up, i'll keep an eye on my mail more often in case i get one as well.
LTHatch is offline   Reply With Quote
Old 03-17-2016, 08:33 PM   #4
yougojay
25, 550 MILES!
Drives: Yaris L Coupe
No, not yet at least...2013 Yaris L base 2 door here. Got a recall letter a year ago in regards to a passenger seat airbag control. Have yet to act on it, nor will I probably ever have it taken care of. Afraid they'll mess the car up with 'fixing' it.
yougojay is offline   Reply With Quote
Old 03-17-2016, 08:54 PM   #5
There are some inconsistent behaviors with the Occupant Classification ECU for the 2012-2013 that I noticed while developing a version of my Occupant Classification Sensor Bypass Module (allows one to use aftermarket seats and still have the passenger airbag work) for the 3rd gen. I would go ahead an let Toyota replace it, as it is a very simple device to replace.
Old 03-17-2016, 09:16 PM   #6
YodaBird
Drives: Gray
Simple Device, Toyota is saying 2.5 hours to replace.
I never experienced this light when driving over certain terrain as stated in the letter, is it a requirement or can I bypass ?
Old 03-17-2016, 09:25 PM   #7
If you don't drive with passengers it is not an issue, but if you do, for their sake I would let them replace it. Replacement should only take about 5 minutes and then another 10-15 to do the calibrations. I am not sure why Toyota plans for 2.5 hours.
Old 03-17-2016, 11:09 PM   #8
YodaBird
Drives: Gray
I do drive with a passenger occasionally, does it still matter ?
The letter says 2.5 hrs, do they want to remove parts from the car ? My dealer has contacted me twice in six months for my car.
Old 03-18-2016, 12:37 AM   #9
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Unless something required tearing out the dash I would follow pretty much all part replacement letters they send especially when it comes to airbag deployment. The worst case scenario could including an accident where an occupant is seriously injured or killed. You are honestly knowingly placing them in danger without having it changed.
I recently brought my sedan in for the seat rail, the spiral cable, and the power window controller. The total time by the letters was 6 hours. I was in/out in an hour and 15 minutes.
Sent from m-o-b-i-l-e
Old 03-18-2016, 04:21 PM   #10
YodaBird
Drives: Gray
It is the Occupant classification system sensor; used to control the operation of the supplemental restraint systems (SRS), including the front passenger air bag.
Effecting;
Certain 2012 - 2013 / Yaris
Certain 2013 / Avalon
Certain 2012 - 2013 / Camry & Camry Hybrid
Certain 2012 - 2013 / Prius C
Who knows maybe when it's brought it they don't have to do anything, then again maybe it's a ploy to get you if your car needs repair.
Old 03-18-2016, 05:15 PM   #11
fnkngrv
fnkngrv's Avatar
Not to be argumentative, but that sounds pretty cynical. I doubt any manufacturer would go to that length to attempt to get paid work from a customer.
Old 03-18-2016, 05:18 PM   #12
YodaBird
Drives: Gray
It sounds cynical but it happens, the world of cars and repairs is, as you know not full of sugar plums and gum drops. The customer goes in for a recall or something of that nature; were told they need to fix, a & b. Free recall, is money for the dealer, or mechanic.
Old 03-18-2016, 05:32 PM   #13
fnkngrv
fnkngrv's Avatar
I get it. Personally I have never encountered a recall with Toyota that ever ended up with a dealership saying, "oh by the way". I have dealt with plenty with GM and Ford as well and yet to experience that. I have seen that type of behavior at a mom n pop shop, but never a dealership. All it takes is a phone call to report it and they will be investigated.
Last that I will say of that. Don't want to continue to derail the thread.
Old 03-18-2016, 05:49 PM   #14
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Unless something required tearing out the dash I would follow pretty much all part replacement letters they send...
Curious why you might not have a recall done if it required pulling the dash?
Old 03-18-2016, 06:00 PM   #15
fnkngrv
fnkngrv's Avatar
From what I have hard that has been experienced by other folks for example on the TSB for the heating system on the 07/08 many said that their dash cover assemblies didn't sit right after the work was completed.
Old 03-18-2016, 06:01 PM   #16
YodaBird
Drives: Gray
TSB ?
The recall says; certain, as I mentioned, maybe mine won't need it, or maybe they replace because, well, they just feel like it, even if it doesn't need replacing,hrm.
Old 03-18-2016, 06:02 PM   #17
fnkngrv
fnkngrv's Avatar
Technical Service Bulletin rather than a safety recall.
Old 03-18-2016, 08:55 PM   #18
dragoonmc
Drives: 07 hatchback
I work for Toyota and I can guarantee that they know exactly what cars have the issue is the reason it is very targeted
dragoonmc is offline   Reply With Quote
Most Reliable Makes of 2010 2007yariz General Yaris / Vitz Discussion 16 12-02-2010 04:37 PM
2007 Yaris hatchback pre-wired for Cruise control? naeemishaq General Yaris / Vitz Discussion 5 11-15-2010 11:31 AM
