Old 12-03-2015, 10:42 AM   #1
AzianCuz
conundrum562
AzianCuz's Avatar
Drives: Toyota Yaris 2007 Type S
Send a message via AIM to AzianCuz
Angry Burner Rubber Smell
So I have my S/C on Medium setting and when I WOT from stop to about 80MPH and after I just brake to park it. Once I do that I smell a strong burner rubber smell from inside the hood... Not sure what it is, does anyone have the same problem or know anything about this?
Appreciate any help.
BLITZ S/C|MICRO-IMAGE CRANK PULLEY|NST ALT;WATER PUMP PULLEY|BLITZ SUS SHORT RAM;HEADERS;AXLE-BACK EXHAUST|2.25 PIPING|1ZZ INJECTORS|OPTIMA YELLOW-TOP|GTSPEC FRONT STRUT;MID LOWER CHASSIS;4 PNT FRNT LOWER BRACE|WHITELINE REAR SWAY;BUSHINGS|TANABE FRNT SWAY|TRD LOWERING SPRINGS/SHOCKS|R1 CONCEPT DRILLED & SLOTTED ROTORS|EBC GREEN PADS|THROTTLE SPACER|XTREME PERFORMANCE CHIP MOD
AzianCuz is offline   Reply With Quote
Old 12-03-2015, 10:55 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Old 12-03-2015, 10:56 AM   #3
Bluevitz-rs
Your belt is slipping.
Old 12-03-2015, 12:45 PM   #4
AzianCuz
conundrum562
AzianCuz's Avatar
HA-HA I just got it re-tightened...? I wonder if it's my grounding wires or header. The smell seems to come from the right side of the 1NZFE engine. The belt side doesn't really smell. For sure it's a distinct plastic burning smell.
Old 04-04-2016, 08:40 PM   #5
Rednaz
Drives: 2006 Yaris 1300
Might be your caliper piston that's staying engaged? I recall the plastic smell since I fixed mine 2 weeks ago.
Rednaz is offline   Reply With Quote
Mga Bagong Kayaris ! ! ! syntax Middle East 749 04-26-2021 03:40 AM
Burnt smell in cabin at high speed in cold weather grilled cheeseus DIY / Maintenance / Service 13 12-15-2018 08:29 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 10:08 PM
Burning Rubber Smell??? :S colinr5779 Yaris TS Talk 12 02-28-2010 12:55 AM
smell like a burning rubber when accelerating highwaypass DIY / Maintenance / Service 5 05-25-2009 09:15 AM
