Old 04-07-2016, 03:40 AM   #1
Pinchlite
Drives: 2007 yaris HB
Switch on the clutch pedal
I have owned a few standards in the past but none have needed as much force to start the car(2007 HB)I really need to push the clutch right into the floor in order to enable the ignition switch.Just wondering if anyone else has found this to be an issue.I will take a look under the dash to locate the switch on the weekend to see if I can somehow adjust it.
Pinchlite is offline   Reply With Quote
Old 04-07-2016, 07:40 AM   #2
bronsin
bronsin's Avatar
The switch on my echo got water in it and froze and the car wouldn't start!
Repace the switch or short the wires together in it so you don't have to depress the clutch.
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Squeaky Clutch Pedal? Kaotic Lazagna DIY / Maintenance / Service 43 05-29-2016 01:15 PM
Clutch safety switch wire description. Kill switch? Add on? valchrist90731 DIY / Maintenance / Service 2 08-03-2015 09:04 PM
Clutch pedal assembly interference with foot Connoisseur_of_fine_cars General Yaris / Vitz Discussion 4 09-23-2011 10:57 AM
