Old 04-29-2016, 06:40 PM   #1
Germ
Drives: 2014 yaris
60K what to check or replace?
I drive a lot in my Yaris. I have 2014 hatchback SE. I just hit 60,000 miles on the car. Just put new tires on the car. What else should I do to the car. I keep up on the oil. I'm think plugs and the wires, anything else I need to do. I saw the chain thing. I'm sure my chain is good for ever for the most part. The window has crack, but not looking to fix that anytime soon.The only thing done to the car is tent the windows and put a Stereo system in it.
Germ is offline   Reply With Quote
Old 04-30-2016, 10:39 AM   #2
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I've got 87k on mine and the only thing I've had to replace was the water pump and the brake rotors/pads. You could replace the plugs if you want, but if the car isn't doing anything funny IMO just run it.
Old 04-30-2016, 10:57 AM   #3
Germ
Drives: 2014 yaris
ok, all the miles on my car are free way miles. I don't drive in town much.
Old 04-30-2016, 11:16 AM   #4
ex-x-fire
Cabin air filter.
ex-x-fire is online now   Reply With Quote
Old 04-30-2016, 03:57 PM   #5
zoidberg444
zoidberg444's Avatar
Generally with my Yaris i service the brake hardware once a year, make sure its all moving freely and not caked up with crap and check the state of the pads and discs. Adjust the drum brakes, handbrake cable.
Change the oil every 7000-10,000 miles and the filter. Keep the brake fluid topped up.
Once a year i change the air filter and the cabin air filter.
Every 2 years 20k-30k miles i change the brake/clutch fluid in the reservoir and bleed the brakes/clutch and i also do the spark plugs at that interval as well.
When i change the oil and service the brakes when its on the jack stands i do a full check of the steering and suspension that there's no play in the wheels or bearing noise. Check for any obvious damage to the steering and suspension and take a look underneath for any signs of rust or leaks.
All I've had in 110K is exhaust, water pump and an alternator. Oh and a battery. And 8 tyres besides servicing. My trailing arm bushes and front control arm bushes are a little perished but not bad yet.
The Toyota coolant is like... 100,000 miles/10 years. Mine is a 5 speed manual still on its original clutch. I think the chains last easily for the life of the engine as long as the oil is kept topped up.
Old 05-02-2016, 05:59 PM   #6
alnen
Drives: 14 Yaris
Good God man! You do a lot of spark plug changes!
alnen is offline   Reply With Quote
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
how much does the first maintenance service cost hans_fh DIY / Maintenance / Service 25 07-05-2007 10:01 AM
Great site to check out!! jdubau55 Off-topic / Other Cars / Everything else Discussions 2 03-11-2007 06:22 PM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
