![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Mar 2016
NGK 5464 Iridium IX vs NGK 4996 Laser Iridium Spark Plugs
Buying new plugs for my 2007 Yaris. I've had it a week and it currently has 106,000 miles on it. RockAuto has the NGK 5464 Iridium IX for $5.93 & the NGK 4996 Laser Iridium for $6.07. At that price I was just wondering the difference? Preference?
Thanks, Russ |
Any plug will last 100k now so it's moot.
My wife's Camry has 130k on the plugs and it's running like it did 12 years ago.
100k change interval.
THATS IT!
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
i have the ix plugs when i got my Vitz RS counter parts from japan, ecu tuning, header etc. purpose of the plugs are to handle more heat/heat range...if you abusing your car like me or turboed, go for higher range plugs like ix or laser 😀
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
interesting, if you go to the ngk web site it shows the 4996 as OEM and the 5464 as on option
same heat range,same gap, same resistance, but the 4996 has a 8mm center electrode for longer life, where the ground electrode of the 5464 is tapered for "faster starts and better acceleration". !!?? I blew up the pic and the ground is tapered,sure as heck. So if I take a dremel to the ground on the 4996 do I get a faster,longer life plug?
http://www.partcat.com/ngk |
| Bigger Spark plug? | samuraivince | Performance Modifications | 6 | 08-05-2014 05:09 PM |
| bought iridium spark plugs but need help | Shinare | DIY / Maintenance / Service | 24 | 08-05-2013 01:21 AM |
| So You Just Have To Have Iridium Spark Plugs eh? | bronsin | General Yaris / Vitz Discussion | 32 | 04-17-2012 03:14 PM |
| Laser plugs? - Awesome | Altitude | Off-topic / Other Cars / Everything else Discussions | 1 | 04-24-2011 09:02 PM |
| Where do I buy ngk iridium tip 7 heat spark plugs? | PETERPOOP | Performance Modifications | 23 | 03-08-2009 09:34 PM |
