Old 05-13-2016, 09:30 PM   #1
slimits
Drives: 2012 yaris hatchback
Unused plug in rear hatch door 2012 yaris
I have taken the rear hatch cover off my 2012 yaris to fit a rear reversing camera and found a plug that isnt used it had 3 wires going in they are blue black and brown could this be the plug for the camera?
slimits is offline   Reply With Quote
Old 05-14-2016, 11:50 PM   #2
slimits
Cool
Well i bought a 12 volt tester the one that lights up and tested the 3 pins for power their was none . I then turned on ignition and put it in reverse and tested the first pin for pwer no power showed up but the doors locked. I then tested the second pin and the doors unlocked nothing happened when i tested the third pin......wierd??????..
Old 05-15-2016, 03:54 AM   #3
slimits
Could someone please help me,it seems to me the plug is only active when ignition is on or if in reverse or both. Why doesnt it show power when i test it.?
Old 05-15-2016, 04:40 AM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I found the same plug when I was fitting a reversing camera on my 2012 Yaris.
Some versions of the yaris had a key lock fitted to the rear hatch, and I think this most likely connectedd to the lock to operate the central locking. When I tested the wires, it made no difference if the ignition was on or off. another thread here somewhere poimts out that the camera connector (if present) has four wires.
There isn't any handy wiring in the rear hatch for the camera, but there is a blank plate where a factory camera could be fitted. I installed an after market camera using the blank plate as a mount point.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 05-21-2016, 10:09 PM   #5
slimits
Thanks for info kevinj gues i will have to pick up reversing wire somehow,, any clues for this?
Getting ready to buy a 2007 Yaris hatch Type456 New YARIS Purchase Forum 26 02-17-2014 12:48 AM
