#127 |
2010EGGHATCH
Drives: White 2010 Yaris Hatch Join Date: Apr 2016
Just have to follow what the comment above you says and you'll be good
Sent from my SM-G920T using Tapatalk
IG: 2010EGGHATCH |
#128 | |
![]() Drives: 2015 Toyota Vios Join Date: Jun 2016
i have saved some important pointers from this thread about the swap. another question is do we need to have a piggyback ECU to tune the A/F mixture? since we are running 55mm TB, doesn't that make the fuel mixtures lean? so basically what i understood on my back-read.
then ENJOY?? |
#129 |
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
You've forgotten about the chip swap. Not sure though if the swap is required for the 0D030 TB version.
Sent from my LG-D801 using Tapatalk |
#130 |
#131 |
feed my pet
I bought the 0D030 and did not require a chip swap
#132 |
hello everyone,
what is the chip swap for? i mean every throttle body has a wiring socket right? so i will just unplug the wire socket from the 2nzfe TB then snap it into 1zzfe TB? then check if the butterfly opens when accelerator is depressed? i am confused.. if the TB works why do i have to swap the chip? and what is the chip? can sombody post a picture of the chip? :D :D i only know potato chips :D :D |
#133 |
feed my pet
I believe you will have idling issues if you don't do the chip swap. Try to source a 0D030 TB and save yourself the hassle on the chip swap. There's a thread somewhere on it.
#134 | |
thanks for replying |
#135 |
You will need to adjust that screw as well. This is all explained in previous posts in this thread.
Sent from my LG-D801 using Tapatalk Last edited by tarkus; 06-30-2016 at 02:10 PM. |
#136 |
#137 | |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Sent from my SM-J710F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
#138 |
![]() Drives: 08 Yaris hatch back Join Date: Nov 2016
Does anybody know what years and models have the 1zz motor?? I do alot of junkyard shopping lol what car would i find the correct TB??
#139 | |
#140 |
![]() ![]() ![]() Drives: 07 yaris hatchback Join Date: Dec 2016
Uuuu
Sent from my SM-G935T using Tapatalk |
#141 |
2010EGGHATCH
Are we reviving this thread? Lol
Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH |
#142 |
I was just thinking of putting the 1zz throttle body lol I wanna to read the thread later wat u think
#143 |
And any 1zz fit ??
#144 | |
2010EGGHATCH
IG: 2010EGGHATCH |
| TPS reading at WOT with 1ZZ throttle body? | 4/20 NEVER FORGET | Performance Modifications | 14 | 07-02-2023 04:20 AM |
| Installed the 1zz throttle body - | AlexNet0 | DIY / Maintenance / Service | 135 | 08-01-2014 07:57 AM |
| FS: 1ZZ throttle body and Fujita intake | mrbond | Items for Sale by private party | 25 | 09-08-2009 10:21 PM |
| Intake to match the 1ZZ throttle body | fuji | DIY / Maintenance / Service | 2 | 06-17-2009 10:02 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
