Old 11-14-2014, 10:38 AM   #19
Mika
Drives: Yaris 2007
Originally Posted by kustomrtr View Post
Hey, I just wanted to say that I have the same exact issue you're describing. Same low rpm and the ac starts blowing warm air.
I have 6 months with this issue. I changed the fuel pump, spark plugs, air filter, cleaned the MAF, cleaned the throttle body,etc but I'm still having the same issue.
If you find out what the problem is, please update this thread. I'll let you know if I fix it!
Saludos
Count on that.
Thank for bring what you have tried.
Mika is offline   Reply With Quote
Old 08-14-2015, 08:03 PM   #20
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
bump having this issue
monchito18 is offline   Reply With Quote
Old 08-17-2015, 03:04 PM   #21
esse10
Drives: 2009 yaris 2 door
low or erratic Idle
for you folks that are still having this issue of low and erratic up/down rpm at Idle I used to have this same problem and mine went away by just tightening up a little more on the serpentine belt. I figured since these cars don't have the automatic tensioner pulley you'll have this problem from time to time when the belt get's old and stretches. Hope this helps out the next guy out there with idle issues.
esse10 is offline   Reply With Quote
Old 10-17-2015, 05:26 AM   #22
ojgang
Drives: Vitz 2007
Iam having the same problem. any luck?
ojgang is offline   Reply With Quote
Old 04-14-2016, 04:49 PM   #23
jcboy
Drives: Sedan 07
Sorry to necromance, but i'm having this problem now. haven't cleaned the throttle body yet, but i've changed filter, changed gasoline to premium, did "italian tune up" but the problem seems to reappear every now and then.
While on neutral, mine's an MT, while waiting for the stoplight to turn to Green the engine gets "confused" on the idle sometime and then drops low and then stalls.
any luck with the OP?
Old 04-15-2016, 12:00 AM   #24
bairjo
Bad gas/Fuel Filter.
Old 04-15-2016, 02:19 AM   #25
yariseggvvti
Drives: Yaris Hatchieback
replace engine mounts
time to replace engine mounts. left, right and lower.
yariseggvvti is offline   Reply With Quote
Old 04-20-2016, 08:54 AM   #26
jcboy
Drives: Sedan 07
thank guys.
i'm inclined to thinking this too, but i've changed gasoline already. anyway it happens less now, after cleaning MAF (by removal and spraying) and TB (without disassembly, just spraying and cleaning with rag).
however, the issue shows up every now and then.
is disassembling the TB (to clean more thoroughly) going to help? i'm concerned about the DBW (drive-by-wire) hence not being able to move the butterfly/metal plate while disconected, making disassembly a futile attempt.
also, is the IACV "cleanable" if TB is disassembled? (can't seem to figure out where it is by mere virtual inspection)
Thanks in advance
Old 08-08-2016, 11:07 AM   #27
Mika
Drives: Yaris 2007
Any update on this? Has anyone been able to figure it out?
a/c, idle, rpm, speed
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
Rims + tires for a 2007 Yaris sedan Shmomi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-18-2011 04:03 PM
