Old 08-11-2016, 01:17 AM   #19
rabbito
rabbito's Avatar
Cosmetic: Toyota red emblem
Old 08-12-2016, 07:30 PM   #20
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
We disassembled, cleaned, inspected, and transferred the C50 gears over to the Scion driven shaft today.
ArmstrongRacing is offline   Reply With Quote
Old 08-12-2016, 07:56 PM   #21
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Love watching this project.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed.
Future: Turbo.
brushforhire is offline   Reply With Quote
Old 08-12-2016, 09:03 PM   #22
ArmstrongRacing
Data doesn't lie
Here is a side by side comparison of the Yaris & Xb C50 driven shafts. As you can see, the only difference is the number of pinion teeth.
Old 08-22-2016, 09:30 PM   #23
ArmstrongRacing
Data doesn't lie
The differential bearings and seals showed up today, only 7-9 more weeks until the Cusco LSD arrives lol
Old 09-02-2016, 01:14 AM   #24
ArmstrongRacing
Data doesn't lie
Something awesome showed up
http://youtu.be/Vjwhj7OS2ec
Old 09-06-2016, 09:15 PM   #25
ArmstrongRacing
Data doesn't lie
Disassembled, cleaned and measured all of the input shaft parts today. All is well, onto the Cusco LSD prep.
Old 09-07-2016, 12:09 AM   #26
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
synchro rigs are all in good shape?
Old 09-07-2016, 12:41 AM   #27
rabbito
rabbito's Avatar
looking great!! 👉👉👉👉👉👉👉👉
Old 09-07-2016, 04:39 PM   #28
ArmstrongRacing
Data doesn't lie
All syncro gaps are well within spec, and they lock onto the gears.
Old 09-07-2016, 08:45 PM   #29
ArmstrongRacing
Data doesn't lie
Here is the stock open differential on the left, and the Cusco differential on the right... For comparison
Old 09-08-2016, 10:56 PM   #30
ArmstrongRacing
Data doesn't lie
Here is the Cusco LSD assembled and ready for install with the new Toyota bearings and the Scion 4.3 final drive
Old 09-08-2016, 10:58 PM   #31
ArmstrongRacing
Data doesn't lie
Here is the differential in the bell housing
Old 09-08-2016, 11:04 PM   #32
ArmstrongRacing
Data doesn't lie
This is what the differential preload adjusting shim looks like. The one with FF is the shim and the other one is just a case specific washer. They go under the bearing races
Old 09-08-2016, 11:07 PM   #33
ArmstrongRacing
Data doesn't lie
This is how you check preload, the spec is 6.9 - 13.8 inch pounds
Old 09-08-2016, 11:10 PM   #34
ArmstrongRacing
Data doesn't lie
We didn't quite reach the 6.9, so I ordered the one size larger GG shim
Old 09-10-2016, 01:44 PM   #35
ArmstrongRacing
Data doesn't lie
Here is the new GG shim we ordered
Old 09-10-2016, 01:47 PM   #36
ArmstrongRacing
Data doesn't lie
The new shim was the perfect size, we are now at 10.0 inch pounds witch is right in the middle of the specified range (6.9 - 13.8). Now let's assemble the transmission.
Effects of too much trans fluid in the case? (auto trans) detroiter General Yaris / Vitz Discussion 5 02-24-2009 11:08 PM
Manual To Auto bronsin General Yaris / Vitz Discussion 10 12-22-2008 10:32 PM
What RPM's are you americans getting on Auto trans? BMGYaris General Yaris / Vitz Discussion 12 11-02-2006 02:43 AM
Manual vs. Auto littlecarlove General Yaris / Vitz Discussion 25 10-25-2006 08:45 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
