Old 10-06-2012, 06:17 PM   #1
DigitalGuy
Drives: Toyota Vitz
Driver Side Door Not Open From Out Side
i have toyota vitz 2006 and it has Double Locking System and i dont have any idea what is double locking system...
the problem is that..
i unable to open driver side door from outside,
i have try from remote and key but its not open from both
every time open back door and then open driver side door from inside..
is any buddy have idea about this problem...
how can i resolve this problem...
DigitalGuy is offline   Reply With Quote
Old 10-06-2012, 08:52 PM   #2
If you can open it with the handle inside, but not with the outside handle, I would think that the linkage between the outside handle and the door latch is broken. The image below shows the link, which is the metal rod attached to the handle. It may be disconnected on either the handle side or the latch side.
Old 10-17-2016, 06:07 PM   #3
N7Shepard
Commander
Drives: 2007 Yaris Sedan S
Scott, here is my issue: my F Passenger door is locked shut. I was installing a new speaker and did not latch either handle to the open door mechanism. And on the down side, when I placed the door panel back on, the door was fixed in a locked position! So now the door is closed, locked, and neither handle connects with the metal bar, no neither open it, or unlock it for that matter.
I have tried to remove the manual window lever and get at the bar through there, bit that's no good. Also, I tried the door panel arm rest, there is a plastic cover that can be popped off. But still, can't reach it.
Is this a moment where a slim jim come I to play?
Thanks!
N7Shepard is offline   Reply With Quote
double lock, double locking, vitz
Driver side foglight trim gwasabi Willing to Buy by private party 3 03-03-2009 03:11 AM
Replacing driver side mirror? supernes550 Cosmetic Modifications (Exterior/Interior) 4 01-26-2009 11:11 AM
How do you pry open the side markers? PETERPOOP DIY / Maintenance / Service 7 10-31-2008 03:05 PM
MY pAsssenger side door wont open webmaster DIY / Maintenance / Service 11 04-24-2007 07:43 PM
The Driver Side River Nutzoids General Yaris / Vitz Discussion 7 12-14-2006 01:11 AM
