Old 10-30-2016, 06:57 AM   #19
amit87
Drives: MY63 Toyota Yaris 1.33SRManual
HI Gagi.... I did try have a look yesterday and you are right... cannot use the Bluetooth telephone button. The wiring goes to the other buttons on other side of wheel before connecting to the main harness on the steering wheel.
I have measured the tactile switch which seem to be 8x8 smd tactile switch but seems hard to find too. Looks pretty easy to solder on but will either keep a look out for cheap switch with ASL or find a cheap steering wheel from breaker and unsolder a switch. I do like your DIY but I've become "as close to OEM" kind of freak hahaha.
amit87 is offline   Reply With Quote
Old 11-03-2016, 05:48 PM   #20
Alain93
Drives: Yaris 12
Ok Gagi, where did you get all these nice diagrams? I searched Google for days and cannot find any wiring diagrams for the 3rd gen.
Alain93 is offline   Reply With Quote
Old 11-03-2016, 07:06 PM   #21
Gagi
Gagi's Avatar
Drives: Yaris 1.33 vvti 2015
On toyota-tech.eu after registration for free account, you can buy access to various diagrams, manuals etc.
You can buy from one hour to one year. In my opinion, the best is one day subscription because you will have to learn how to scroll, search, save what you intend to.
Upon entering your VIN you will have filtered access to specific manuals and diagrams for your car.
Many of them you can save as pdf, but some you will have to save as full HTML.
So if you really want diagrams, spare one sleepless day and one more for your rest.
Gagi is offline   Reply With Quote
Old 09-23-2017, 04:30 AM   #22
laobo
Drives: yaris sedan 2011
Dear @Gagi i have yaris 2015, whithout ccs swich and im not found (60)A58= ccs pin to add ccs. pls share me diagram if you can..
regards
laobo is offline   Reply With Quote
Old 09-23-2017, 05:52 AM   #23
Gagi
Gagi's Avatar
Is your car 1.33L gasoline european model?
Old 09-24-2017, 08:45 AM   #24
laobo
Dear!this one 1.5l gas, thailan/vietnam model
Old 11-21-2017, 12:21 PM   #25
HDTechVideo
Drives: Yaris MK3 1.33L Dual VVT-i CVT
Thank you @Gagi Thank you so much for helping me to fix ASL.
Thank you @CTScott for the wonderful tutorial How to connect cruise control
What I did
1. Bought cruise control stalk and ASL switch from ebay
2. Connected cruise control stalk and plug the cable
In my case Cruise control is just plug and play
3. Installed ASL switch and added a green cable from ASL and connected the other end to 2nd pin of z2 connector
* Tried ASL but unfortunately it was not working.
4. With help of Gagi found a solution to short the yellow cable that is connected to z2 connector pin 1 to black cable that is coming from cruise control stalk.
So first removed the Yellow cable from z2 connector
Then short that with black cable from cruise control that is going to z7 connector
5. ASL is working
* Before removing yellow cable for short with black cable make sure it is not connected with any cable on the connector that is located on the back side of steering wheel.
Cheers
Sent from my SM-G935F using Tapatalk
HDTechVideo is offline   Reply With Quote
Old 08-31-2018, 02:21 PM   #26
laobo
Like
Old 08-31-2019, 06:54 AM   #27
Umarzafar88
Drives: Vitz 2011 with 1NR-FE engine
I have Vitz 2011 (jdm) Gen 3 and swapped 1KR-FE 1.0 to 1NR-FE 1.33 dual vvti.
I need to install cruise and ASL.
Ecu pic is attached. it's 89661-52Q90
Need ecu pinout or CCS and ASL pin plz
As spiral cable is also need to install.
Sent from my LYA-L09 using Tapatalk
Umarzafar88 is offline   Reply With Quote
Old 10-05-2022, 05:03 PM   #28
mik23
Drives: yaris 2005
All,
I have 1NRFE Engine MT NSP120 chasis, I have installed the Cruise control light didnt comeup Any help highly appreciated.
I am not sure what is not working I have clutch switch installed and assumed wiring is also installed.
https://ibb.co/dQkH984
https://ibb.co/h2JwSXf
https://ibb.co/9njjTcw
https://ibb.co/XVw0qYw
mik23 is offline   Reply With Quote
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Retro fit Cruise Control into a 2009 Yaris hatchback 42ezra Performance Modifications 1 05-03-2009 12:04 AM
