Old 11-20-2016, 12:51 AM   #1
Ramon1691
Ramon1691's Avatar
Drives: 2007 Yaris hatchback
Alternator voltage
Hello hope someone can help me out what should be the normal voltage for the alternator on the Yaris? Because mine is showing 13.70 to 13.60 under load I haven't tested with 2000 rpm yet and when I hooked up a tester it says that is charging within normal range but not strong on the 14 volt I got the tester at harbor freight tools if someone is interested in picking one up dirt cheap, mark my question is should I replace it now or wait till the light starts to flicker if it even does?
P.s i found a alternator at a wreck yard on a 08 yaris sedan with 8000 miles on it
Ramon1691 is offline   Reply With Quote
Old 11-20-2016, 04:26 AM   #2
jra
Drives: 2015 yaris L
13.7, 13.8 is fine, if it puts to much voltage it will boil the water out of your battery. If it was mine I would use it until it quit, I had a olds I had to replace the alternator every two years about 25,000 miles, but I've had other cars that the alternator lasted over 200,000 miles.
jra is offline   Reply With Quote
Old 11-20-2016, 08:40 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
you have how many miles on the car now?
Voltage is normal. Test at 2-3K rpm
Old 11-20-2016, 09:23 AM   #4
Ramon1691
Ramon1691's Avatar
Thanks for the replies I have 160000 miles vitz
Old 11-20-2016, 09:24 AM   #5
Ramon1691
Ramon1691's Avatar
I guess I have one of the good ones since is the original oem because I did my research and it appears there is an issue with the voltage regulator on the 07's with corrosion
Old 11-20-2016, 11:15 AM   #6
dogsridewith
Drives: 2007 2-door hatchback
Alternator
Having a spare alternator is not a bad idea.
