Old 11-28-2016, 07:58 PM   #1
guy2can
guy2can
Drives: 2012 Yaris SE
P/S Pressure Switch P0552
Hi all,
Had to change the power steering pressure switch (PN: 89448-51010)on my sons 2004 Echo HB, the code P0552 was coming up once the car was started after every code clear. I tried cleaning the connector, but in the end went to the wreckers and paid $20.00 CAD for a used one. From the dealer and parts places, this little baby is $275-300 CAD. It is about $125. USD at Autozone under PN: PS442.
So changing was fairly easy with the car on ramps and accessing the switch from below with a 1 1/16 wrench. The hardest part was getting the connector to release without breaking the lock. The K Ohms readings in the amber column were alot more on the bad sensor.
cheers,
guy2can is offline   Reply With Quote
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 54 Yesterday 08:40 PM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
