![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
squeal or screetch
heard a high pitch screech/squeal coming from the motor area during high RPM shifting today. It almost sounded like bearings going bad or something, only did it for a few seconds while high rpm shifting, then went away. Anybody have a clue what is going on here? water pump bearings , alternator bearings ?
Before speculating on anything as radical as bad bearings, I'd suspect belt slippage. Bearings would make themselves known under far more circumstances than high rpm shifts.
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
it was probably just your tires spinning under the ultimate engine torque. watch that beast!
bearings
well I've heard bearings and fans luck up before and it almost sounded like it. I know how a belt sounds when it sqeeks and it didn't seem like that. I haven't heard it ever since I held back on THAT BEAST. LOL
![]() I'm shifting at a lower rpm to make sure. thanks for the input folks. |
![]() ![]() Drives: 2015 yaris L Join Date: Jun 2016
Car telling you in Japanese, please don't drive me so hard? Most likely a belt, could be the throw out bearing or clutch complaining, but I doubt it.
| Belt Squeal mystery solved | Carquestions | DIY / Maintenance / Service | 7 | 05-04-2016 05:27 AM |
| Intermitent Clutch (i think) Squeal | alex22808 | DIY / Maintenance / Service | 12 | 10-23-2014 07:04 PM |
| 07 HB Mechanical Noise Cold Squeal | Fidelio | DIY / Maintenance / Service | 0 | 09-12-2012 11:29 PM |
| squeal on startup (audio) | N9QGS | DIY / Maintenance / Service | 5 | 10-21-2009 12:42 PM |
| Brakes squeal. | AlexNet0 | DIY / Maintenance / Service | 11 | 05-01-2009 03:47 PM |
