![]() Drives: Toyota Yaris 2d Join Date: Dec 2012
2012 yaris 2d door panel removal
Hi all. I saw a post about removing a yaris door panel (supposedly in 30 seconds :) but when I look at my 2012 yaris its definitely not a match for the pictures and instructions.
Someone had knocked my driver side side view mirror off and I've bought a replacement, now its just down to figuring out how to get into the door where the attachment bolts are. Can anyone offer some assistance on this? Thanks very much. (Automatic 2d yaris, manual rolling windows--the pin removing instructions for the handle were spot on, no power mirrors just manual adjust, I can take a picture of the inside of the door for reference if it would help) |
It looks like the door panels for the 2012 mount about the same as for the prior generation.
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
^ Sorry for off-topic: Just noticed you have a scoop on your blue car. Is it purely cosmetic?
Would also be very good to see what gauges you have and how those are installed. Thanks P. |
#4 | |
For gauges, I have a multifunction gauge that I created that mounts in place of the clock (which gives me real-time AFR and all of the things you would see on a device like the scangauge (RPM, intake air temp, water temp, etc.). I also have a boost gauge that I mounted to the cover of the driver's side glove box.
^ Thanks
#6 | |
Drives: 2012 Toyota Yaris Join Date: Dec 2016
Pleas Help a Damsal in distress
Ok I am in desperate need of help. I am trying to replace my passenger side mirror on a 2012 Toyota Yaris 4 door with manual windows but I can only find one screw on the door panel. I have looked everywhere and can't find out how to take off the door panel so I can replace the mirror. Please any help would be appreciated.
A damsal in distress |
You have to pry off the armrest. There are 2 screws under there securing the door panel. After that you have to pry off the panel itself. Then there are 3 bolts holding on the mirror. Good luck.
| Tags |
| mirror door panel |
| DIY Cruise Control for 2012 Yaris - Good News! | CTScott | Third Gen Yaris General Discussion | 305 | 10-27-2025 01:52 PM |
| 2007 yaris snow tires on 2012 | lomky | Third Gen Yaris General Discussion | 4 | 11-16-2012 02:00 AM |
