Old 12-17-2016, 09:34 PM   #1
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
Termostat won't open??? O7 YARIS H.B
So I randomly grab the bottom radiator hose after 30 minutes commute so was cold so I got a new termostat but is doin the same after goin to Gillette stadium is like 1 hour drive still won't open it got heat and won't overheat ?????
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 12-17-2016, 11:40 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
how cold is it outside?
Old 12-17-2016, 11:44 PM   #3
Yaris874
Yaris874's Avatar
35°f
Old 12-18-2016, 12:09 AM   #4
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
So 1.6°C ... i assume you have proper amount of glycol in your cooling system .... and if not it still won't freeze on that temperature anyways :/
KimmoKekki is offline   Reply With Quote
Old 12-18-2016, 08:03 AM   #5
Bluevitz-rs
Is the upper hose hot?
Coolant returns into the engine down there so it's possible it's been cooled down by the rad to the point of not feeling hot anymore.
Old 12-18-2016, 09:19 AM   #6
ex-x-fire
The top one should be the hot side. One these engines, when the t stat opens, it lets coolant into the engine.
Old 12-18-2016, 10:05 AM   #7
dogsridewith
Drives: 2007 2-door hatchback
Thermostat heater cooling system temperature gauge.
The cabin heater is also a radiator cooling the system coolant. I would like a temperature gauge. My 1989 Tercel temp needle ran high for awhile. Then, I'm guessing, the thermostat or some blockage unstuck and it ran dead center again. Then the needle ran low and I stuck some cardboard behind the grille. And then got normal again. (Note: approach to non safety-critical items evolved as death-by-rust-inspection approached.)
But this dual-idiot-light-no-gauge approach of Yaris gives no such ability to track trends enough before extremes.
Old 12-18-2016, 11:05 AM   #8
tmontague
tmontague's Avatar
What others have stated above. Check the top hose, it has cooled down enough by the time it reaches the bottom hose as well as through your heater core.
I find the 1nz cools very efficiently when outside temps are low
Old 12-18-2016, 11:19 AM   #9
KimmoKekki
KimmoKekki's Avatar
And forget to mention ... malfunctioned radiator cap causes that kind of problems !
Old 12-18-2016, 12:45 PM   #10
jra
Drives: 2015 yaris L
If you have drained coolant recently, you may not have gotten all the air out of system?
jra is offline   Reply With Quote
Old 12-18-2016, 12:53 PM   #11
Yaris874
Yaris874's Avatar
The upper hose get hot and is pressure on the hose
Old 12-18-2016, 12:57 PM   #12
Yaris874
Yaris874's Avatar
Ok I will change the cap thanks
Old 12-18-2016, 12:58 PM   #13
Yaris874
Yaris874's Avatar
Yes I just did a water pump like two months ago
Old 12-18-2016, 01:41 PM   #14
dogsridewith
Is overflow tank at correct level? Do you get illumination of the high temperature indicator lamp?
Old 12-18-2016, 03:28 PM   #15
Yaris874
Yaris874's Avatar
Yea but never gets hot
Old 12-18-2016, 04:42 PM   #16
IllusionX
Drives: 07 Yaris Sedan Aero
You are saying you are not getting heat inside the cabin?
The heater core could be blocked....
Old 12-18-2016, 04:49 PM   #17
Yaris874
Yaris874's Avatar
No i get heat
Old 12-19-2016, 08:00 AM   #18
dogsridewith
lower radiator hose temperature coolant thermostat heat heater
We ALL now need to be curious and check the operating temperature of the fleet's lower radiator hoses...noting, at mimimum, ambient temperature.
Who remembers the SoCal H.B. Yaris meets? I've got pics... ern-diz California 3 04-27-2015 11:18 AM
