Old 01-25-2017, 10:40 PM   #19
SirDigby
Drives: 2007 yaris 3 door
Originally Posted by JustDidIt View Post
Good idea... as the charge pipe does run thru that area... so wrapping will be in order. Thx!
also, adding a rigid charge pipe, then wrapping it in gold will further reflect heat. i love goooooooooold!
Old 01-30-2017, 09:29 PM   #20
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Quantum turbo kit on 1NZFXE NHW20...Prius?
Greddy E-Manage Ultimate arrived today. Still haven't made any more headway on the ECM pin outs. Been referencing the 1NZFE diagram for help.
JustDidIt is offline   Reply With Quote
Old 01-31-2017, 03:43 AM   #21
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
this has really peaked my interest. . .Have you ever driven a 1NZFXE prius in comparison to the one you have in the shop that has the 1NZFE?
Its a metal frame simulator with all of the ecus and mechanicals exposed. Its fully functional but without power steering.. I will send a picture soon :)
ncp13 is offline   Reply With Quote
Old 02-01-2017, 02:35 PM   #22
JustDidIt
JustDidIt's Avatar
Upgraded Injectors
Anyone have any info on this?
Anyone know the actual specs on the 1ZZFE injectors? I've heard an array of answers on the CC range.
Looking at these - both listed for the Toyota 1.8
23250-22040
vs
23250-0D050
Anyone know the difference?
Old 02-04-2017, 02:48 AM   #23
KenTK808
Drives: 2014 Yaris LE
not going to lie. was looking at this turbo kit when it went on ebay too
KenTK808 is offline   Reply With Quote
Old 02-04-2017, 08:14 PM   #24
JustDidIt
JustDidIt's Avatar
Ya, I wasn't "watching" but kept seeing it and wasn't about to pay $1500. It had sat for months on eBay.. I suppose that it sat so long that whom ever it was... just wanted it gone.
Old 02-04-2017, 08:25 PM   #25
JustDidIt
JustDidIt's Avatar
Anyone have a preference over the two spark plugs?
NGK (2667) BKR7EIX with Gap: .031
VS
NGK (6988) BKR7EIX-11 IX with Gap: .43 (closer to OEM specs)
After scouring the old threads..Looks like the Blitz guys swear by the smaller .31 gap of the BKR7EIX 2667 so that's what I bought..
Old 02-10-2017, 12:21 AM   #26
JustDidIt
JustDidIt's Avatar
Been looking into tuners in the Texas area...
PRT Performance flat out said "No!" to me and the prius. lol
MVP Motorsports Inc also said "No!"
Dallas Performance - still need to call
EngineLogics - still need to call
The company i work for has offices in Austin and Houston so if I don't have any luck in Dallas, i was planning on hitting up Meghani Motorsports in Houston - they have done some work with MapECU and a turbo 2GR lotus.
I'd definitely check out Boostlogic and or Cobb if i can get a contact to confirm what they can work with Toyotas.
Dynosaur Performance was at least able to recommend a guy, Dusty from DAP Tuning, he's been busy, but i'm following up with him. He originally thought he could tune the oem ECU. He's been anle to do some stuff with the Tunda. So far this is the most promising yet i still have my doubts knowing the past history of people attempting to modify the ecrypted toyota ecu...
I'm currently trying to figure out if I can make my own custom ECM harness so I won't have to cut up my OEM wiring. Looks painstaking and tedious....
Old 02-12-2017, 11:52 AM   #27
JustDidIt
JustDidIt's Avatar
Realized my earlier post of the first ever supercharged then Turbo NHW10 1999 Classic Gen Prius story - the PDF didn't attach, so here it is again.
It's a good read - the trouble that Julian Edgar went thru to get the Prius up from 43kW (57hp) to 55kW (73hp)...a rough 30% increase in power. I'm hopefully I can get more..
The article just goes to show what i'm up against... in for a world of issues...
Summary of Turbo Modifications:
• Turbo – GT1241 from hydrogen turbo kit
• Fabricated exhaust manifold – Hydrogen Turbo Kit
• Fabricated intake and intercooler plumbing – 2 inch and 1.75 inch mandrel bent – Hydrogen Turbo Kit
• One heat range colder Iridium spark plugs – 2 step colder NGK 2667
• Intercooler – Hydrogen Turbo Kit came with a Spearco
• 2-inch exhaust – Car is already setup with a custom 2” Magnaflow exhaust.
• Airflow meter – use the one I made for my custom air intake
• Intake airbox – Will use a cone style filter, not concerned with the extra noise from not using a air box.
Still need to buy:
• GFB recirculating blow-off valve
• Turbo oil lines
• Fuel supply system – in-tank pump, external pump, two pressure regulators, solenoid, one-way valve, two control relays
Still need to figure out:
• Electronic switching of oxygen sensors and fuel pressure via the Simple Voltage Switch kit working off airflow meter signal - Hopefully the Greddy EMU will help with this.
• Airflow meter electronic interceptor – Hopefully the Greddy EMU will help with this.
• Decrease in high load boost using a solenoid-controlled bleed on BOV pressure line via Simple Voltage Switch working off airflow meter signal – Either Greddy EMU or some other Electronic boost control.
• Engine 'on' signal provided for 30 seconds after boost event via a modified Simple Voltage Switch working on hybrid ECU 'full air con request' input – still need to figure that out.
File Type: pdf 1st_Supercharged_then_Turboed_NHW10_Prius_optimized.pdf (2.10 MB, 35 views)
Old 03-17-2017, 12:28 PM   #28
JustDidIt
JustDidIt's Avatar
Test fit the Header and Turbo. Ordered some oil lines and connectors. Puzzle is starting to come together.
Old 06-17-2017, 05:21 PM   #29
JustDidIt
JustDidIt's Avatar
Well, this happened.
Decision has been finally made - ALL non-damaged aftermarket stuff has got to go. Car is being totaled and damage is more than the car is worth. Shameful...
All aftermarket parts being sold... :(
Old 06-17-2017, 05:23 PM   #30
JustDidIt
JustDidIt's Avatar
I'll start a new thread in the for sale section... this is painful to do.
This is my 2nd Prius to total and neither were my fault. I'm getting a check for this one, but I can't fix it for the amount, I'm getting.
Old 06-17-2017, 09:55 PM   #31
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
Sorry to see the project end like this. Glad you're safe!
heeroyuy01195 is offline   Reply With Quote
Old 02-16-2018, 08:46 AM   #32
JustDidIt
JustDidIt's Avatar
Posted the turbo for sale here.
Quantum Technology Hydrogen 1NZ Turbo Kit GT1241
https://r.tapatalk.com/shareLink?sha...0&share_type=t
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
WTB Turbo kit ynnek317 Willing to Buy by private party 5 07-04-2014 02:53 PM
For Sale: ZPI Turbo Kit CTScott Items for Sale by private party 27 12-10-2013 07:00 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
