Old 02-01-2017, 12:41 PM   #1
madtv261
Drives: 2008 Toyota Yaris Hatchback
08' Yaris HB burning oil
Hello Yaris World Community,
In the last three months, my 08' Yaris Hatchback has burned oil almost completely dry. Only when it's near the very end will the Oil Pressure light and Check Engine light come on. Goodyear was unable to help and the Dealer said they would need to do an engine tear down which costs $650, and then fix the problem which they estimated could be up to $2000. The car is nearly 10 years old and I regularly get the vehicle serviced, I love my car. I am not experiencing any kind of odor or smoke of any kind, but I'm wondering what alternatives I might have before I invest that kind of money into an older car. I do intend to buy a new vehicle by years end, but for now, does anyone have any advice as how I can fix the engine for a much cheaper price? Any help would be greatly appreciated.
Thanks in advance,
Kevin
madtv261 is offline   Reply With Quote
Old 02-01-2017, 04:36 PM   #2
yarisfitch
Drives: 2010 Liftback
How many Miles on it and is it burning or Leaking the oil ?
yarisfitch is offline   Reply With Quote
Old 02-01-2017, 04:39 PM   #3
madtv261
Hey yarisfitch, 173,000 miles, and it for sure is not leaking oil as two mechanics have checked that
Old 02-01-2017, 04:47 PM   #4
dogsridewith
Drives: 2007 2-door hatchback
Oil level dipstick low pressure indicator check engine light
You fill by regularly checking the dipstick...not waiting for "the very end" or for lights to come on. This type of maintenance leads to an early very very end.
Ditto with coolant level.
And brake fluid level.
Old 02-01-2017, 04:49 PM   #5
madtv261
Right, but the point here is that this is just now becoming a problem of the engine burning oil. That is precisely why I'm looking for assistance on how to resolve this issue. I now have to keep oil in my car to top it off as the oil level depletes faster than before
Old 02-01-2017, 05:19 PM   #6
Rigaud
Drives: 2009 Yaris
Ok but you haven't answered a very important question. Do you regularly verify the oil level on the dip stick or wait till the light comes on?
Old 02-01-2017, 05:24 PM   #7
madtv261
Since the second time this has happened, I've been checking the dip stick about every 3 days to verify oil level
Old 02-01-2017, 06:05 PM   #8
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
defective PCV valve?
My wifes Spark had a issue (they all did) with a poorly designed PCV valve & would suck straight oil right into the intake manifold. Luckily I caught this early and spliced in a catch can. I had to drain it every 2 days until they had a recall with a better part. I still run the catch can but it gets a trace amount in 7500miles
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-01-2017, 06:08 PM   #9
madtv261
Malibuguy, thanks for the suggestion. With this in mind, i'll see if my mechanic can look at it to see if it warrants replacing. I'm a novice when it comes to cars so all your input is much appreciated
Old 02-01-2017, 06:19 PM   #10
Rigaud
Drives: 2009 Yaris
Well theirs the main error to start with. Once that red light comes on for oil.....engine needs to be turned off immediately and not turned on till the oil level is rectified. Also theirs quite often some premature wear if it's neglected to the point of having the dash light go on. Plus this happened twice. :/ That light goes on when theirs no oil pressure.
Old 02-01-2017, 07:06 PM   #11
Rigaud
Drives: 2009 Yaris
Also did you have your oil changes done at 5,000km intervals?
Old 02-01-2017, 07:18 PM   #12
madtv261
Yeah, whenever the MAINT Required light comes on, I have it serviced. This is a new issue that I've now encountered twice. If there is something more simple than an engine tear down that is very costly, I'm hoping to find an alternative fix
Old 02-01-2017, 07:56 PM   #13
Rigaud
Drives: 2009 Yaris
Leak down test and compression test!!!!
Old 02-01-2017, 07:57 PM   #14
madtv261
Thanks for the advice! I hope that's cheaper than 650 for an engine tear down
Old 02-01-2017, 11:23 PM   #15
IllusionX
Drives: 07 Yaris Sedan Aero
At this point, might as well just replace the engine.
Old 02-03-2017, 10:06 AM   #16
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
If you're just going to get a new car at the end of the year, just keep it full of oil and drive it.
Otherwise, get a used engine and swap it in.
Old 02-03-2017, 08:13 PM   #17
ex-x-fire
What weight of oil are you using? My wife's Taurus calls for 5w20, it uses oil when I ran that weight. I put in 10w30 & have no more oil useage.
Old 02-03-2017, 09:53 PM   #18
tmontague
tmontague's Avatar
As stated earlier first to check is the off valve. Then do a leak down test. If it isn't a simple off valve Then I'd just do an engine swap at an an independant mechanic.
If you're engine has been run until the light goes on then it's been run lower than 3 psi (iirc) and could have some damage due to that. A new engine swap should cost around $ 1500 give or take.
Yaris engines don't just burn oil like that, either your pc is severely stuck open or something else happened.
Checking oil in the Yaris jb48 General Yaris / Vitz Discussion 16 09-15-2015 05:15 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-14-2014 12:17 AM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-07-2012 12:37 AM
Did they increase the oil capacity for 09 Yaris? 2007yariz DIY / Maintenance / Service 8 05-18-2011 10:28 PM
