Old 02-16-2017, 01:07 PM   #19
B.B._07
Drives: 07 5dr
Originally Posted by tmontague View Post
Can you confirm if you have to remove the head to remove the rooming cover? When I replaced the head gasket on my echo I have to remove the timing cover to remove the head but I'm pretty sure the head can stay in when the timing cover is removed.
Just want some clarification
To remove the timing chain cover or oil pump (the oil pump is built into the timing chain cover) you need to remove the valve cover but certainly not the head. If you're getting a leak from the timing chain cover area it could also be the crankshaft seal.
Old 02-16-2017, 01:25 PM   #20
Hershey
It's the timing chain cover .
Old 02-16-2017, 04:13 PM   #21
Ramon1691
Ramon1691's Avatar
Drives: 2007 Yaris hatchback
Hey
The mechanic that I took it to at a small shop said that it doesn't need to be resealed right now since is a very small seep I pointed out to him that it was shocking across the middle of the engine and he mentioned that oil travels everywhere but he did also mention that if it was his car he wouldn't resealed because it such a pain in the ass and considering the car mileage to just let it be and top off as needed but is crazy tho why would Toyota use that sealer instead of the black one which is better because you can see atleast in my case coming out of that gray rtv and spreading lol
Ramon1691 is offline   Reply With Quote
Old 02-16-2017, 04:16 PM   #22
Ramon1691
Ramon1691's Avatar
I can't hate on the Yaris tho is been pretty reliable besides the p0012 code I got which Toyota insisted it was the camshaft gear thank god it was just the ocv, cheap to run reliable has never let me stranded when I replaced the valve cover gasket that's motor was sooooo clean fine little engines
Old 02-16-2017, 04:49 PM   #23
Ramon1691
Ramon1691's Avatar
By the way does anybody now where I can get a repair manual for the Yaris? I when to auto parts store but can't find any and not trying to spend a fortune on one
Old 02-16-2017, 06:39 PM   #24
Ramon1691
Ramon1691's Avatar
Question
If anybody can help I will appreciate it now if me and by buddy who is a mechanic where to attemp to reseal the timing cover what would you guys recommend? Replace some components in there? And could I reuse the timing cover or just buy a new one? Also I understand is a pretty long job, does the head come out of just the upper part of the engine? And how long does it take for the sealer to dry?
Old 02-16-2017, 09:46 PM   #25
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by dogsridewith View Post
all in 2 hours? (head gasket or valve cover gasket?)
It was the valve cover. :)
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
