Old 03-03-2010, 10:09 AM   #19
Originally Posted by sbergman27 View Post
The taller sidewall offsets the smaller wheel size by 20%. But my point is really that, overall, there is not much difference between the two configurations. The 15 is 3.4% higher diameter. The 14 is 4.9% narrower.
1010tires.com suggests no more than 3% difference when buying new tires
that said, i ran 205-55-15 all last summer vs my 175-65-14 stock stuff and i personally think the speedometer was more accurate.
@ 120kph, 3.4% can be the difference between getting pulled over or not getting pulled over...
Old 03-03-2010, 12:27 PM   #20
Hershey
I'd rather have the 14s' than the 15s' . The smaller / thinner tires do better in rain and snow . Plus give little better mileage . The '92 Ford FESTIVA with four 12" studded snow tires would go through or up snow coverd roads / streets with ease .
Old 03-04-2010, 05:50 PM   #21
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
big tires keep RPM's low at highway speeds... I run 15's... would be tempted to go with 16's if I ever bought wheels. Most of my miles are put on at speeds above 40mph.
About 1/3 of my miles are done on 1000 miles trips at 70mph every third month. even my drive to work is half 40+ mph, and half 20-35mph.
Old 03-20-2010, 12:14 PM   #22
docB
Drives: '09 Yaris Sedan
Originally Posted by Cosworth View Post
electric PS in Yaris totally blows. I believe it is one of the culprits in why Yaris handles so weird at highway speed.
as for the original comment/question, I really don't think you're gonna see much gas saving based on 14 vs. 15 tire comparison.
I think there's more gas to be saved by just getting an ecometer and drive steadily.
I have never had weird handling at any speed. I run 42psi front and 35 psi rear. The thing is rock steady and hands free on the highway at 2500 rpm in 5th gear. Sedan w/ 15" wheels. The 14" are slightly narrower, smaller diameter and weigh less. Things that improve acceleration, ride quality all with less rolling resistance. I am working on putting 185/70-14s on some light weight alloys I own. Can't wait to get that in place. Just have to defeat the tpms first.
doc
docB is offline   Reply With Quote
Old 04-11-2010, 04:02 PM   #23
Falconeer
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options
Stock Tire - 175/65R14 >Search Tires Tire 1 - 185/60R15
Section Width: 6.88 in 175 mm Section Width: 7.28 in 185 mm
Rim Diameter: 14 in 355.6 mm Rim Diameter: 15 in 381 mm
Rim Width Range: 4.5 - 6 in Rim Width Range: 5 - 6.5 in
Overall Diameter: 22.95 in 582.93 mm
Overall Diameter: 23.74 in 602.99 mm
Sidewall Height: 4.47 in 113.53 mm
Sidewall Height: 4.37 in 110.99 mm
Radius: 11.47 in 291.33 mm
Radius: 11.87 in 301.49 mm
Circumference: 72.09 in 1831.0 mm
Circumference: 74.58 in 1894.3 mm
Revs per Mile: 906.3
Revs per Mile: 876.1
Actual Speed: 60 mph 100 km/h
Speedometer1: 58.0 mph 96.6 km/h
Speedometer Difference: - Speedometer Difference: 3.447% too slow
Diameter Difference: - Diameter Difference: 3.33%
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
Falconeer is offline   Reply With Quote
Old 04-11-2010, 05:27 PM   #24
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
EPS is a delusion just like the Prius is a delusion. If its so good how come the Yaris is rated 29 mpg and the ECHO is rated 34 mpg?
Taller gears for the Echo.
Old 03-20-2017, 06:16 AM   #25
birdman
Drives: '08 Blazing Blue Yaris LB
Usually the diameter of the tire is the same on the 14 and 15" Yaris wheels. The difference is that the tire on the smaller rim has a taller sidewall that absorbs more road shock and softens the ride a bit. It also reduces the cars cornering ability somewhat.
birdman is offline   Reply With Quote
Old 03-20-2017, 08:54 AM   #26
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I think we have a winner for the oldest thread resurrection. Over 7 years!!
Old 03-20-2017, 01:28 PM   #27
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
On Instagram
On Wheelwell
Old 03-20-2017, 03:22 PM   #28
bronsin
bronsin's Avatar
How about another star for the OP?
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 07:40 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 07:58 PM
16 inch tires???? bigpej Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-26-2007 10:39 AM
FS: Stock 15 inch Steelies, Tires and Hub Caps.. thomasward00 Items for Sale by private party 4 07-01-2007 04:53 PM
Are there any real adavantages to spoilers and 15 inch tires? nwdixieboy General Yaris / Vitz Discussion 5 02-17-2006 11:08 PM
