Old 03-08-2017, 02:30 PM   #505
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I got my passenger air bag done now my passengers are safe again.
Well, as safe as they can be anyway.
(insert evil laugh here)
Old 03-30-2017, 10:44 AM   #506
Steveh27
Drives: 2010 3dr hatchback auto red
Got my notice re power window switch.
Steveh27 is offline   Reply With Quote
Old 12-28-2017, 10:04 PM   #507
Teshian
Drives: Toyota Vitz 2008
I have 2008 toyota vitz, when i stop @ traffic light or just in traffic it revs and races even when my foot is on the brakes. I have changed the crunk senor, change the pump and gas filter. A full oil and plug service. The test say the crunk senors was bad, it also said the computer needed re learning. Did all of that no change. I need help
Teshian is offline   Reply With Quote
Old 12-29-2017, 01:05 PM   #508
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Got my passenger airbag, seat rail, and spiral cable done yesterday. No more airbag light and flashing seatbelt indicator. Yeah! Our 06 goes in for those three and two more recalls (don't 'recall' exactly what the other two are) in May or June, when the car comes out of hibernation.
Old 01-16-2018, 01:32 PM   #509
zoidberg444
zoidberg444's Avatar
Mine is going in to have its recall done on Monday. I have 3 recalls on mine.
Passenger Airbag Inflater
Seat rail spring
Drivers door switch
I've been getting letters about it since 2014 at least but its only in the last 9 months that I could spare the car for a day to get it done. I called the dealer about this in July and it took them this long to get round to ordering the parts and booking me in.
I think they were hoping to sell me a new car first. I kept getting letters about "scrapage schemes" it really burns my bacon how wasteful it is taking such lovely reliable cars off the road and scrapping them even though they have 10+ years running in them just to replace it with a newer less reliable vehicle which won't last nearly as long.
UK to Nordkapp in a Yaris
Old 01-23-2018, 12:36 AM   #510
zoidberg444
After getting letters in the post for probably close to 3-4 years I finally took Betty in to have her recalls done. Took it into Toyota at 9AM yesterday morning, sat down and had a coffee and used the wifi while they did the 3 recalls.
Took them about 2.5 hours.
Passenger Airbag inflater
Seat rail spring
Drivers door switch
All done. It must have horrified them to put so much work in on an 11 year old car. They did try and sell me a new one. I was like no thanks. Not even halfway through her life yet.
I also seem to get less squeaking and rattling in the cabin now its all been out.
Old 01-23-2018, 04:42 AM   #511
miiser
miiser's Avatar
Drives: yaris 2009
Ye, if you think about it they had to pull out the whole dash to change the passenger airbag. So they screwed again every bolt that had become loose
miiser is offline   Reply With Quote
Old 01-23-2018, 09:17 AM   #512
zoidberg444
I'm impressed they managed to do it in only 2.5 hours to.
Sent from my SM-T713 using Tapatalk
Old 01-23-2018, 09:32 AM   #513
miiser
miiser's Avatar
Drives: yaris 2009
Toyota Recalls
It might be not that hard. Some screws here and there. And I assume they did this more than just one time so they know what to do.
First time I took out my door panels took me about 5-10 mins. Now, after 3-4 times, I can do it in about 30 sec
Old 01-23-2018, 09:34 AM   #514
zoidberg444
First time I took out my door panels took me about 5-10 mins. Now I can do it in about 30 sec
I suppose so. The one job that would intimidate me in the Yaris or any car is pulling the dash out.
Old 01-24-2018, 09:50 PM   #515
miiser
miiser's Avatar
Drives: yaris 2009
I called Toyota support today to find if there are any recalls for my car. Turns out I have to change both Takata airbags (I knew it anyway) and something I didn’t saw from anyone here referring : they need to check my driver’s window switch
Old 01-24-2018, 09:52 PM   #516
miiser
miiser's Avatar
Drives: yaris 2009
Toyota Recalls
Also what about the front seat’s airbags? Aren’t they Takata, or they are just too cheap to issue a seat replacement?
Old 01-25-2018, 10:27 AM   #517
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
The driver side airbag is something I've had in the back of my mind since they announced the recall on the passenger side. I assumed they're both made by Takata, but was hoping the very different design of the driver side unit would save it from being recalled. Hearing that they told you both driver and passenger airbags need to be recalled is worrisome
On Instagram
On Wheelwell
Old 01-26-2018, 01:32 AM   #518
miiser
miiser's Avatar
Drives: yaris 2009
The driver’s side airbag is easier to change anyway. I assume it will take less than 2 mins for them. Just call them and they will tell you. I think that you will have to change it too.
The passenger side is the hard one thought,because they have to take off the whole dash. I am worried about it because they may scratch something or not screw it back, properly.
Old 01-26-2018, 11:44 AM   #519
ern-diz
ern-diz's Avatar
That was a concern of mine, too. Fortunately, the dealership I went to did a fantastic job. My inside/outside air selector actually worked better after the airbag change than prior to. I wonder if they broke it during the swap and replaced it, because it truly feels better than ever.
I think I still have the link to the vin checker, so I'll have to keep an eye out for word on the driver side.
On Instagram
On Wheelwell
Old 01-26-2018, 03:40 PM   #520
miiser
miiser's Avatar
Drives: yaris 2009
Vin check for me wasn’t helpful.
It showed that I have no recalls whatsoever, but I had 3.
Just call them and ask. I called Toyota support they answered the phone right away, they asked me my license plate and the told me what recalls I have.
I think you were lucky. I wish they will make nice job to me too.
I called them they will order the parts and when they arrive, I will arrange an appointment.
Old 01-26-2018, 03:45 PM   #521
ern-diz
ern-diz's Avatar
Good luck!
On Instagram
On Wheelwell
Old 01-29-2018, 09:42 AM   #522
miiser
miiser's Avatar
Drives: yaris 2009
Good luck!
Thank you. I will update you guys when I change them
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
Toyota Temporarily Suspends Sales of Selected Vehicles redglare45 Off-topic / Other Cars / Everything else Discussions 0 01-26-2010 06:33 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
Toyota recalls vehicles over faulty engine Lizardboy General Yaris / Vitz Discussion 1 07-18-2006 07:07 PM
