![]() ![]() Drives: Olive yaris,FRS, Dakota R/T Join Date: Aug 2013
How to access alternator bolt to remove alternator or replace belt
Hi all, I use a 1/4 drive 14mm socket and a 1/4 to 3/8 adapter to a big Armstrong thin head locking flex ratchet (11-994). Here's some pics.
The photos show I didn't have to remove a/c line fasteners.
Another way is a 3/8 flex ratchet and a 3/8 socket but when you break alternator bolt loose don't hit the a/c hose.
If you broke that 14mm bolt loose with a small wrench the first time you should enter arm wrestling contests. The bolt is on really really tight from the factory. After I broke loose for the 1st time it is easy to loosen as I torque it to the factory spec of 40lbft( for some reason it is on much tighter than 40lbft from factory). Now that it's torqued properly I could probably break it free with my long handle matco 1/4!drive ratchet.
![]() ![]() ![]() Drives: 07 yaris hatchback Join Date: Dec 2016
The u take it out ??
Sent from my SM-G935T using Tapatalk |
Yea it is I had to take out the size 10mm slide the bracket for the ac line to the side and was out my alternator light is Ben on for almost a year but the alternator still work
with my way 10mm ac bolts stay put. And a gearwrench torque wrench fits. The 3:8 to 1/4 adapter with 1/4 drive 14mm socket clear the alternator but still leaves room for ratchet to clear a/c lines. Bolt is so long I might have removed the 10mm bolts. Definitely do not have to remove 10mm bolts to move alternator to remove and tension belt.
| Fuel filter replacement | jaimico | DIY / Maintenance / Service | 43 | 03-07-2023 11:05 AM |
| Blitz Supercharger Belt Slip @ Higher RPM? | Freestylin | Forced Induction Forum | 20 | 09-06-2017 07:32 AM |
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
