C60 6 speed questionS
AY! I just want some infos about the C60 6-speed transmission.... I know that with a bit of cutting, it fits the 1NZ just fine, but someone made me doubt about a thing or two...
first of all... are they all 6 speed LSD? a friend of mine bought a C60 from a Vibe GT and the guy who had it, said it was a LSD transmission .... I'm a bit skeptical about that... second thing, will there be any improvements in my driving for swapping to a C60? (MPG or km/L ... because Canada... , etc...) and finally third, is it really worth it ? |
You don't want a C60, you want a C160. And you need to swap the bell housing from your stock transmission. The C60 uses bigger axles and not all C60s are LSD.
What cars were the C160 found in? Also, is it a direct bolt on or is there some internals that need switching?
Nvm, just searched your trans swap thread. Due to the 2zr being much wider I doubt the 6spd trans would fit without serious alterations to the frame rail.
C60 or C160 there is the question ...
| DIY Cruise Control for 2012 Yaris - Good News! | CTScott | Third Gen Yaris General Discussion | 305 | 10-27-2025 02:52 PM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 09:11 PM |
| The most economical speed for the Yaris. | Ilovemyyaris | Fuel Economy Forum | 3 | 03-19-2012 12:33 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 06:31 PM |
