#37 | |
2010EGGHATCH
Drives: White 2010 Yaris Hatch Join Date: Apr 2016
Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH |
#38 |
^^ok just making sure. That really sucks though.
#39 | |
![]() ![]() Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
The biggest difference that comes into play between your time and mine is that our engines are different. I have the 1NZ, and even with a wheel/tire setup that is heavier than stock and an axleback I've been able to get a 10 second range 0-60 with everything stock otherwise. Sticky tires can take away performance of a car also. They have a higher rolling resistance, which basically means that you need more energy to move them than a tire with lower rolling resistance tires such as snow tires or energy conserving tires. With the 2SZ being limited on power already as is, sticky tires can negatively impact the performance. Honestly, just by adding an intake and exhaust isn't going to make any car much faster (there are exceptions). It will however make your car louder, and if that is what floats your boat then |
#40 | |
![]() ![]() Drives: 07 yaris Join Date: Dec 2016
#41 |
Bump if anyone could point me in the right direction to get my intake to work
#42 |
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
If the screw holes are that far off it might be better to drill new holes and tap them if there's enough material. If not then I would say try and find a different intake or at least a section with a MAF mount. I think someone had one posted in the classifieds section on the forum. Can you put up a picture or two of the hole alignment?
#43 |
Does the sensor fit in the hole? The screws aren't esencial, they're just there to locate its orientation and keep it in place.
#44 | |
2010EGGHATCH
IG: 2010EGGHATCH |
#45 |
Well if you have tools to make the hole bigger and get the sensor in there you can just seal it with a little silicone and zip ties.
#46 | |
2010EGGHATCH
Ill post updates Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH |
#47 |
Just make sure it's oriented in the right direction and dead nuts straight.
#48 | |
2010EGGHATCH
IG: 2010EGGHATCH |
#49 |
Never thought about zip tying the sensor down. That'll work! I'm guessing if I take a metal file to the hole ill be able to get it to fit. It's not off by much but enough to piss me off hahaha
#50 | |
2010EGGHATCH
IG: 2010EGGHATCH |
#51 |
Nope neither lined up on mine. Both were off about 3-5 mm or so. The maf is less than a mm from fitting but it wouldn't go down. I'd say I'll be installing it this weekend coming & I'll let you know how it works out
#52 | |
2010EGGHATCH
IG: 2010EGGHATCH |
#53 | |
2010EGGHATCH
![]() ![]() Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH |
#54 |
I would be a little weary of the zip ties on the MAF, don't want any leaks there. Maybe you can make an adapter with some aluminum stock.
| Simota CF650-6 Air Intake Review | invader166 | Performance Modifications | 16 | 12-21-2015 03:31 PM |
| For Sale: Fujita F5 Cold Air Intake | invader166 | Items for Sale by private party | 2 | 11-21-2015 11:10 AM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| AEM cold air intake vs Afe intake... | djgab101 | Performance Modifications | 69 | 04-28-2013 02:03 PM |
| cold air intake | 400 dollar yaris | Performance Modifications | 10 | 10-02-2012 06:33 PM |
