Old 07-31-2017, 07:40 AM   #1
sierick
Drives: Yaris S Limited 1,5
Keyless Smart Entry and locking Problem
So I have this problem occurred on my Yaris (S Limited '2012) that has built-in keyless entry from the factory, with keyless start too.
Normally, I can push the switch on driver's door handle to lock the doors and just touch the touch sensor on the handle carrying the fob to unlock the doors.
To make sure that the switch is giving respond, I already do some random test to push the switch with the driver door opened (key inside the vehicle, on passenger seat), and it does a long beep.
Any door lock control using the button near power window control, and remote is working fine
I have come to the toyota authorized repair shop and they tell to change part name "main body ECU 82730-52380" and "oscilator 69210-12321-A0"
I'm curious what is the real problem happen in my car, and where to start the check. Thank you for your attention.
sierick is offline   Reply With Quote
Tags
door, keyless entry, locks
2014 Keyless Entry Install Question GMRelkin DIY / Maintenance / Service 4 03-09-2017 11:26 PM
keyless entry issues azamora General Yaris / Vitz Discussion 0 10-29-2013 08:29 PM
Smart key entry - battery problems. red-demon85 DIY / Maintenance / Service 5 10-24-2013 05:28 AM
Yaris keyless entry not working tash DIY / Maintenance / Service 1 03-05-2013 06:23 PM
I lost my master keyless entry key, need suggestions.... Frankd1 DIY / Maintenance / Service 19 12-01-2010 11:13 PM
