![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
Should I replace this small piece of brake line?
I had worked on the master cylinder many times, and pushed it in and out with the lines attached to see if there is a leak. I had a stripped nut and replaced it by cutting the flare and using another nut I had laying around. I am just worried about the line near the back connecting to the mc. I moved it so many times, and when it was replaced, had a small kink from bending but no leaks. It moves from the bracket being moved. Should I replace it or leave it alone? It has been fine for the past two weeks.
Well, it's not to hard to change that rear one. For peace of mind reasons.
Its pretty badly stuck on the union. Couldnt get it off with my flare wrench, and toyota makes you buy a set of lines not just one. I guess im better off leaving it if it isnt leaking.
| Tags |
| brake line, fluid, kink |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Will this hold? Plastic bag vs brake fluid | lamadoo | DIY / Maintenance / Service | 7 | 04-25-2013 03:35 AM |
| Question on brake bleeding... | Yarflana | DIY / Maintenance / Service | 6 | 04-03-2013 01:55 PM |
| Beware of the "simple" brake job tasks | Yarflana | DIY / Maintenance / Service | 7 | 03-18-2013 02:26 PM |
| Front brake pad replace: calipers piston | dslc | DIY / Maintenance / Service | 3 | 07-17-2010 02:46 PM |
