![]() Drives: Honda S2000, Toyota Yaris 1.3 Join Date: Nov 2017
Toyota Yaris 1.3 vvti -99
Hi!
Does anyone have this kind of issue and how to you handle it. Or do you have solution that problem I have. Now its time to get my wintercar on the run. I faced a problem. My Yaris will start, running 2 seconds and then turn off. I have cleaned MAF sensor and checked cylinder number 1 and 2, and they give a spark. I´ve done that because check engine light is on and OBD error code says P1305. Internet says: Possible causes Faulty Ignition Coil No. 2 Ignition Coil No. 2 harness is open or shorted Ignition Coil No. 2 circuit poor electrical connection Faulty Engine Control Module (ECM). |
Problem solved.
Signal wire to ECM was broken. |
| Slow from cold Yaris 1.3 VVTI | f2raf | DIY / Maintenance / Service | 2 | 03-01-2016 07:42 PM |
| Toyota Yaris 1.3 SR 2007 Start Up Problem | Kishan2511 | DIY / Maintenance / Service | 6 | 05-08-2014 07:22 PM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
