Old 11-27-2017, 07:55 AM   #1
Siray_14
Drives: 14 yaris
Power charger not working?
I looked at both fuse boxes under the hood and didnt see anything I thought was related to the lighter/power outlet, and googling has resulted in foreign owners and fusebox locations my USDM car doesnt have. There HAS to be a fuse to check, and the detailed fuse diagram I found online seems to indicate the charger is integrated into the instrument cluster, but all that works still. Either I am not aware of the corresponding fuse, or there is a mechanical failure (it conked out in the middle of a trip, I use a dash cam, if that helps).
Siray_14 is offline   Reply With Quote
Old 11-27-2017, 01:30 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
There is another fuse panel under the passenger side dashboard. Fuse number 15 in the panel is labelled "CIG". It is listed as providing power to "power outlet, cigarette lighter", and is rated at 15 amps.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 11-28-2017, 07:29 AM   #3
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
That will probably be under the driver's side in the U.S. Kevin. I don't think there's any trim to remove like RHD cars. It's just a matter of standing on your head and removing the fusebox cover!
mrpj is offline   Reply With Quote
Old 12-02-2017, 01:21 PM   #4
Motzking1
Motzking1's Avatar
Drives: 47 2013 yaris l hatchbacks
Instrument panel junction block. 15A(Blue) CIG. Fuse. (Highlighted in yellow) instrument panel Junction block is located forward pf the driver's right knee approximately 3 inch forward of the OBD2 connector
Sent from my Nexus 6 using Tapatalk
Motzking1 is offline   Reply With Quote
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 07:55 PM
