![]() ![]() Drives: 2010 3dr LB Join Date: Sep 2010
195/65R-15 tires
Anyone running 195/65R-15 tires on their stock rims? I run 195/60-15 studded snow tires in the winter, but only mount them when a sizable storm is predicted. Any info is welcome. Thanks, Bill C
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
A 195/65/15 is 5.5% larger in diameter. It would affect fuel economy and acceleration. I currently run 195/55/15 on my Yaris.
Subcompact Culture: The Small car blog |
My neighbour ran 195/65/15's on his 2007. They were HUGE!
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
This is my 3rd season running 195/65/15. Running General all season for the winter.
Never had a problem with a little careful driving. Been through a few good snows. |
I'm just curious: Why would you run 195/65/15?
Most of the time the roads are dry and I'm a little aggressive.
#7 | |
![]() ![]() ![]() Drives: 2014 Yaris Join Date: Feb 2017
195/65R-15 tires
I have 195/55/15 on mine as well. Stock steelies, but I also have wheel spacers. 25mm front, 30mm rear. It rubs in the back. Sent from my iPhone using Tapatalk |
I want to try the larger tires on my stock rims as a bridge between my 185/60-15 summer tires on aluminum rims and the 195/60-15 studded snow tires on stock steel rims. As I have found in the 2 small snow storms we have had so far the summer tires are horrendous. The studded snows are not very good when it is above freezing on non snow covered roads. Bill C
Just a Gaijin
You really shouldn't have a problem with 195/65/r15, but why don't you just go with 185/60's ? Narrower tires are better in snow anyways and they are usually cheaper.
What's the point of upsizing? |
So I had my Hankook Optimo 724 tires mounted today. These are the 195/65R-15 tires that I got on Walmart.com for $45.33/tire. It was $58.00 all in for mounting, lifetime balancing, lifetime rotation, TPMS rebuilds, and tire disposal. Before they mounted them they confirmed that I knew they were larger than the original tires. I only put about 30 miles on them but my initial impression is they ride a little bit better than the original tires. Bill C
#12 | |
Nice, good to know. Does the taller tire have any other noticeable differences? Any rubbing? Sent from my iPhone using Tapatalk |
Post some pics of your car on 195/65/15's.
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback Join Date: Jul 2016
I run 195/60R15 on my 2014 Yaris that I use for work. I noticed it's a little slower than the other's at acceleration because of it but the mileage hasn't suffered. Main reason for getting them was the clearance pricing that Walmart had... Bridgestone Ecopias for $22 a tire... sadly they only had four or I would have bought more and I've called every other walmart I could find within two hours and they were all sold out.
-Karl the Uber/Lyft Driver |
![]() Drives: '08 Yaris, '00 Miata, Join Date: Oct 2016
Same here
This is an easy to use picture resizer:
http://picresize.com/edit Click "Browse" Open your pic to be resized Click "Quick Resize" Chose 75%, 50%, or 25% Click "I'm Done..." Click "View Image" Save your resized photo to your file. |
First impression - Hankook Ventus S1 Evo | DiCaprio | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 12-22-2020 09:51 PM |
Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
2007 Yaris bad tires | weaver615 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-27-2010 07:21 AM |
