Old 03-27-2018, 05:15 PM   #1
tmontague
tmontague's Avatar
BC Racing BR coilover installation help (or Megans)
I got my BR's in the mail yesterday and will be installing them this weekend but I was prepping the mounts to test fit everything and noticed that the BR's come with a spacer that sits on the front strut stem. It is the same as seen in the picture in post #25
http://www.yarisworld.com/forums/sho...t=33290&page=2
I noticed that with the spacers the bearing doesn't sit very flush to it and it doesn't mate and put perfect pressure on the right spot on the bearing. Without the spacer, the bearing fits perfectly flush and makes good contact with the top spring perch.
My question is can anyone confirm that the spacer is needed or has anyone ran either BR's or Megan coilovers without the spacer?
Without the spacer I had to move the spring up about 3mm for proper preload but other than that I see no issues.
Old 03-28-2018, 08:59 PM   #2
Dliverance
Drives: 2012 Black sand pearl <3
Can you post some pictures?
Dliverance is offline   Reply With Quote
Old 03-28-2018, 11:07 PM   #3
tmontague
tmontague's Avatar
I'll try and post some later this week, it's been a hectic week.
I figured out that the spacer is needed and the bearing ends up seating fine as long as you raise the spring lower perch up a few 3mm when adjusting preload
Old 04-02-2018, 03:44 PM   #4
Dliverance
Did you ever end up getting some pictures? My bilsteins are on back order for up to four months and I don’t feel like running that many events stock so I might cancel the order. I’m just a little bit skeptical about bc coilovers still.
Old 04-03-2018, 09:23 PM   #5
tmontague
tmontague's Avatar
The spacer definitely needs to be on there and is installed in this oders: spacer>bearing>nut>rubber isolator/topmount
I'll post a review up once I've had enough seat time on the BC's. Time will tell how durable they are, and they are definitely on the lower end of the price range but still are not cheap. I would put Megan's in that category (BC makes them) but not these. The build quality seems really good and I've been very surprised at how DDable the 7k F 9k R springs are. I thought it would be jarring but its honestly not much harsher than my old set up. Expansion joints can be more noticeable but they are still DDable and I even had my 16month old in the backseat the other day with my wife and her comment was "I didn't even noticed a difference"
For Sale: D2 Racing Complete Coilover Set (fits 2006-2015 CTScott Items for Sale by private party 15 07-15-2017 12:08 PM
BC Racing Coilover Installation AOR 1-1 DIY / Maintenance / Service 7 03-28-2016 05:19 PM
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 03:40 PM
12/20/08 Buddy Club USA 5th Anniversary Clearance SALE DuckinOut California 3 12-18-2008 01:25 AM
