#37 |
Contact Scott and spnywoosh for the anti blue sticker gang. Haha but looks good in running a similar set up with my own tiens. A rear sway bar only helps alot
I also love the way the front end looks. i wonder if I could somehow throw on the later model front on my ncp90... Last edited by Runethecursed; 05-29-2018 at 01:16 AM. |
#38 |
Super cool.
#39 | |
![]() ![]() Drives: 2012 Black sand pearl <3 Join Date: Feb 2018
What’s the anti blue sticker gang all about and do you mean you run a similar spring rate? I went 5k front, 6k rear to eliminate the need for a rear sway bar. I did have some understanding this weekend but I had no adjustability in the front |
#40 |
I meant shock valving, Im full hard on the rears and the fronts are midway to low, but I also havea huge rear sway bar and a front k member brace and SFC's so its a little stiffer all around
And anti blue sticker gang https://spinnywhoosh.com/collections/racing-numbers #justsaynotobluetape |
#41 |
Ah. So far, my coilovers are behaving the way I want them to. This venue has two big turn arounds. Usually one in the beginning and one in the end of a course. I had no issues with the first one but I would understeer a bit on the second one. I’m not sure if I should blame myself or my tires. I also went in pretty damn hot. I don’t think I will be needing a rear sway bar yet but I will see how the car does in the next event. I’m also bringing along a friend of mine to help dial it in. He’s Tomago on the forum here. He’s pretty suspension saavy so his advice will go far. I believe he made the suspension sticky here.
As for the magnets, I usually order from magnets on the cheap but those Castrol magnets really move me. |
#42 |
That name rings a distant bell...
#43 |
im the one who designed those magnets for Scott.. ;)
#44 |
He drove a turbo XA and a spyder but he also made Yaris rear hub spacers and toe shims.
You sir are awesome. I just ordered the traction fluid I needed for the supercharger. My car will be going under the knife for the install within the next two weeks. I’m looking forward to the bump in power. I also ordered a Megan axleback. My car needs full exhaust but I need some sound. I’ll be getting a header and full cat back soon. I’m on the fence about ordering a TRD rear sway bar but I’m not entirely sure I need it yet. The car handles like it’s on rails as is and I don’t want to ruin that. |
#45 | |
and I wouldnt change anything suspension wise till you get more wheeltime |
#46 |
I need to look into that sard part. As for seat time, I agree. I need to learn the behavior of this car a bit more. One event is too little to make a decision about the car. I was hoping it would behave like the other FWD cars I’ve autox’d but it’s a completely different machine.
#47 |
I just scored a pretty decent deal. eBay is giving 20% off with a coupon so I grabbed a rear sway bar for $156 shipped and new. My exhaust came in yesterday but I think I might wait until the bar comes to install it.
#48 |
awesome, I didnt know Ebay had a 20% off coupon... I think Ill pass this time. I really want to start exhaust work on my car now
#49 |
It was only for today. If anyone is interested it’s pickdadsgift at checkout. I guess it’s a Father’s Day promotion. I didn’t expect it to actually work but it did.
#50 |
Dad gifts are car parts right?
#51 |
Lol I’m guessing it was anything. I was able to use it on the sway bar and a main breaker for my house.
#52 |
#53 |
#54 |
I also need to lower the rear. That’s as low as it goes in that picture. I need to remove the adjustable perches to go lower.
